Op com not reading interface (sometimes)
+ Reply to Thread
Results 1 to 7 of 7
Thread: Op com not reading interface (sometimes)
  1. #1
    Hi All,
    9-5 1.9 Vector auto, using windows vista laptop
    op com software is latest version 150406b
    I am at a bit of a loss. I have a normal OBD reader which I use with Torque and it does the job.
    I invested in an opcom however as it does more and I want to regen but I am having connection issues.
    Initially it wanted to be activated, so I slapped my details in and it said Ok thanks like (or words to that effect)
    next I tested the device and got this message
    Firmware version V01.60
    interface test ended successfully.
    I then go in and select diagnostics, scroll down and select GM based Saab, Select 9-5 but when I try to get it to do anything it is looping in the 'Diagnostic connector' popup with the following message
    "Checking interface.......
    Error: Interface not found
    Please connect the interface to the usb etc....
    In the interface type within settings, I have tried all 4 different options, (revision C,C+ then the same for b D & A
    I am at a loss as to what is going wrong, as I know the car is fine as the other unit works. The interface is connecting to the laptop unless I try to get anything done, when it just gives the error.
    Any help appreciated.
    thanks
  2. #2
    Join Date
    Nov 2009
    Location
    Cheshire.Uk
    Posts
    4,745
    Re: Op com not reading interface (sometimes)
    what yr is the 9-5..
    My 9-3 audio,2 x cd changers,aux-in & Bluetooth audio streaming..
    Is still running Factory oe coils with a tune..
  3. #3
    Sorry she is an 2006 on a 55 plate
  4. #4
    I will upload the software to an old XP laptop and see if it works, I will report back.
  5. #5
    Saab Anorak
    Join Date
    Dec 2003
    Location
    Peterborough,Cambs,UK
    Posts
    786
    Have you tried linking to it as a Vectra CDTi.
    I used opcom briefly a couple of years ago with my 1.9TID 9-3 (57 plate) and it would only talk to it as the Vectra at that time.
    You should be able to work with it considering you have the same engine Z19DTH.
    I still have the software I used at the time...I can probably upload it somewhere if needed.
    I know there are issues with the different firmware versions and the functionality is limited ...in the end I bought a clone Tech2
  6. #6
    Saab Junior
    Join Date
    May 2016
    Location
    Essex, England
    Posts
    29
    I've got the same Op-com software as you & am having the exact same problems with it trying to properly read my 2.2 TiD. Seeing as the software & interface were cheap, I concluded that it was probably a load of rubbish & binned it.
    I don't have Tech 2, but I do have Delphi DS-150 E (chinese copy version, so about £60) software & interface & this seems to work great in reading practically the entire car.
    Hope this helps.
  7. #7
    Well I tried it today and all was well. how odd.
  8. Remove Advertisements
+ Reply to Thread
  1. Fibre Optic interface for Parrot
    By jynx78 in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 07-17-2013, 08:14 PM
  2. Tech 2 interface
    By aqsw1230 in forum Help, Advice, Saabs and Motoring
    Last Post: 05-27-2010, 05:39 AM
  3. FOR SALE. 9-3/5 cellular interface lead
    By robp in forum Saab Parts / Accessories, FOR SALE and WANTED
    Last Post: 01-24-2007, 01:09 PM
  4. Alpine are designing display interface
    By bayesp in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 05-09-2004, 05:20 PM
  5. infotainment/phone interface
    By ylee coyote in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 03-19-2003, 05:43 AM
