It is recommended to use only oils approved for your engine according to the table below. Services should be performed at the recommended intervals to optimize your engines performance throughout its service life.
9-3 and 9-5 with 4-cyl and 6-cyl petrol engine
Long Life engine oil that is approved in accordance with GM-LL-A-025 specifications with the recommended viscosities :
0w-30 or 0w-40 (for lower mileage cars)
5w-30 or 5w-40 (for higher mileage cars)
9-3 and 9-5 1.9TiD engine
Long Life engine oil that is approved in accordance with GM-LL-B-025 specifications with the recommended viscosities :
9-3 1.9TTiD engine
Fully synthetic engine oil that is approved in accordance with GM-LL-B-025 specifications with the recommended viscosities :
0w-40
Vehicles manufactured on or after 2010
Dexos2 is required for all 2010 new GM / Opel / Vauxhall / Chevrolet diesel and gasoline models (dexos2 is also backward compatible with older specifications)
Mobil 1™ ESP 0W-40 and Mobil Super™ 3000 Formula G 5W-30 are fully approved to meet the specific GM requirements.
Please see here for more information on dexos2 products http://www.mobil.co.uk/UK-English-LC...ubricants.aspx
This thread will be locked if anyone has any comments please contact a member of the team, or if still unsure to your requirements then either contact your supplying retailer or are sponsored vendor Opie Oils.
This thread will also be added to over times outlining the service requirements for both petrol and diesel vehicles.
Big thanks to Kez for taking the time to produce this.
In addition if you want to know more about oil then this is a very informative read, also covers issues such as sludging, flushing oils changing from one type of oil to another, etc. Required reading for 'Petrol-heads!"
http://www.carbibles.com/engineoil_bible.html
9-3 1.9TTiD engine
0w-40
