ACC fault code 00
+ Reply to Thread
Results 1 to 8 of 8
Thread: ACC fault code 00
  1. #1
    ACC fault code 00
    Hi all.
    So my electrical gremlins seem to be mounting up.
    During a long trip my ACC has suddenly packed up.
    It was functioning perfectly fine for the first part of the journey, then I stopped for a short pit stop. When I started the car again the ACC displayed 00 on startup, then the screen went dead and refused to function.
    I turned off the ignition, same result. I can't even calibrate it, it just displays 00 every time then shuts down, buttons do nothing.
    Have searched for similar symptoms, but everything I can find relating to code 00 just seems to clear itself up. Not for me so far...
    I've detached the ACC module to check for anything obvious but all appears fine. The fuse is also ok.
    Perplexed...! Any ideas anyone?
  2. #2
    Administrator kez's Avatar
    Join Date
    Aug 2011
    Location
    uk
    Posts
    7,041
    Re: ACC fault code 00
    try disconnect battery for a while and if its still there try pressing auto and off at same time
    as you are prob aware 00 means no fault lol as you say gremlins
  3. #3
    Thanks for the reply Kez.
    I've disconnected the ACC unit several times. Fully removed it. Even takin it into the house in case theres some kind of in-built proximity reset! () Would this differ from disconnecting the battery? Also would disconnecting the battery cause anything else in the car to reset?
    The 00 lasts for about 4-5 seconds (also the display seems brightly backlit at this point, more so than usual but this may just be me?)
    One the 00 goes away the unit goes dark and no combination of buttons have any effect, including the reset combination. ACC unit is just dead.
    Really stuck on this one...!
  4. #4
    Ok, so have disconnected the battery for 10 minutes, ACC behaviour the same, 00 code then nothing....
    Hoping someone has some ideas?
    Have run out of ideas what to look for / reset...
  5. #5
    Join Date
    Aug 2011
    Location
    uk
    Posts
    7,041
    with you saying the display goes bright when first powered up it is highly possible that one of the components on the circuit board has failed capacitor or diode the most likely course
    another thing is a dry joint or tracking
    can you take it apart and take a look at the pcb.............see if any comonent has swelled/bubbled or split or if any white dust type stuff around soldered pins
    with you saying above this would cause the system to power up but shut down once lets say a faulty capacitor can not maintain charge or one part of the circuit cant get the info it requires due to component fault
    sometimes you will get symptoms of a failng component where as it will have a hicup on powering up from time to time and rectify itself for a while other times it will power up/shutdown or just blow this priciple applies to any pcb
  6. #6
    Once again, thanks Kez.
    Your diagnosis sounds more than likely.
    It was suffering missing pixels and I was going to send it off for repair anyway. This has just forced the issue.
    I think i've eliminated most of the obvious fault finding.
    Off it goes to the SID repair man...
    I'll report back and post what he finds.
  7. #7
    Join Date
    Aug 2011
    Location
    uk
    Posts
    7,041
    http://www.ebay.co.uk/sch/i.html?_od...panel&_sacat=0
    not sure which one you have
    missing pixels would not have been the cause(and just put new lcd/led screen) whether or not they can fault find down to componant level i dont know and wether it will be cost effective agaisnt a 2nd hand one even though components are peanuts to buy............because its electronics they think they can charge the earth lol.....................u anywhere near s/wales
  8. #8
    I have the top one from the link, car is 2001 9-3. I've used the repair guy before and had great service, so will give him another try with this one.
    Need to establish if it's the ACC module, or something in the car, hoping it's the former...
    I'm in s/london, not a million miles from s/wales, globally speaking!
  9. Remove Advertisements
+ Reply to Thread
  1. ACC fault code 1_____22
    By maxter in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 03-24-2012, 03:23 PM
  2. ACC fault code 13 - Tech2 2406
    By markvanrooijen in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 02-06-2011, 01:29 PM
  3. ACC fault code 1---21
    By natoqc in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 12-01-2010, 12:16 PM
  4. ACC Fault Code 19
    By shutupwills in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 10-04-2007, 05:53 PM
  5. Fault Code 02 - ACC
    By mark7099 in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 05-21-2006, 03:26 PM
