saab 9-3 ss 2003 aero 2.0T massive oil leak
+ Reply to Thread
Results 1 to 5 of 5
Thread: saab 9-3 ss 2003 aero 2.0T massive oil leak
  1. #1
    had a new clutch and flywheel fitted plus a nsf driveshaft and now i have a massive oil leak.
    its engine oil and its all over my drive.
    what could it be ?
  2. #2
    Join Date
    Nov 2009
    Location
    Cheshire.Uk
    Posts
    4,745
    Re: saab 9-3 ss 2003 aero 2.0T massive oil leak
    rear crank seal has gone by the sounds of it..
    My 9-3 audio,2 x cd changers,aux-in & Bluetooth audio streaming..
    Is still running Factory oe coils with a tune..
  3. #3
    Are you sure it is engine oil? g/box oil looks the same, given what you have replaced could be a driveshaft seal and/or a crank seal.
    We do not stop playing because we grow old; We grow old because we stop playing.
  4. #4
    yes its defo engine oil as i checked the oil last night and its emptied.
    getting the car looked at later today.
    why did the mechanic not change the seal if it is that ?
  5. #5
    Ok, brain dump time - If the crank seal wasn't leaking before the work was done then something has happened to it as just fitting a flywheel wouldn't disturb the crank seal - it it is that leaking of course! given the scope of work and the empty sump it seems likely although if all the oil has drained then maybe a sump/sump plug issue. The crank is at the bottom of the engine but the sump is below, to loose all the oil - did the do an oil change?? was the sump bolt done up, has the sump been off???
    TBH if i had the flywheel off i would have changed the crank seal as a matter of course on an older/higher miles car just to err on the side of caution. If it was changed during the work then the fault and cost to fix lies with the garage - that is if they admit to liability...
  6. Remove Advertisements
+ Reply to Thread
  1. Saab 9-3 Aero 2003 Air Con
    By OllieAero in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 03-26-2012, 05:32 PM
  2. Saab 9-3 Aero 2003
    By woody804 in forum Previous model ranges, FOR SALE and WANTED
    Last Post: 02-09-2012, 05:07 AM
  3. Massive Water Leak - help!
    By Boost in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 11-18-2006, 07:43 AM
  4. Massive Sale of new and used Saab parts
    By saabscene in forum Saab 95 & 96 Two stroke and V4 (1949 - 1980)
    Last Post: 04-13-2002, 07:33 AM
  5. Massive Sale of new and used Saab parts
    Last Post: 03-18-2002, 05:02 PM
