HELP - Mechanical key won't unlock car, battery dead
+ Reply to Thread
Results 1 to 8 of 8
Thread: HELP - Mechanical key won't unlock car, battery dead
  1. #1
    I accidentally left the lights on in my 1999 Saab 9-3 convertible and the battery died so (understandably) the electronic key won't unlock the car. The problem is, my mechanical key will not unlock either door (??) so I can't get in to the car to pop the hood for a jump. Any thoughts?
  2. #2
    Super Moderator haloweenhamster's Avatar
    Join Date
    Mar 2009
    Location
    Bletchley frequent Birmingham & Northampton
    Posts
    1,327
    Re: HELP - Mechanical key won't unlock car, battery dead
    Call a auto locksmith or aa/rac/green flag or make a small cut in roof/smash a window
  3. #3
    Saab Newbie
    Join Date
    Oct 2012
    Location
    WestMidlands
    Posts
    5
    Quote Originally Posted by LaraK View Post
    I'm not familiar with the Saab locking system but I do know other marques that have 'dead locks' can be opened with the mechanical key by inserting the key and turning forcefully towards the unlock position, then try the handle whilst the key is still turned.
    May be worth a try before you do any damage...
  4. #4
    The key should work regardless of the battery situation. Is it possible that they're not the correct keys for your car? have you previously tried to open the doors with the keys?
    A previous owner may have changed the ignition switch but not bothered with the door locks. You could get a new key from a dealer using your VIN. If the deadlocks are on then you still won't be able to open the doors even if you get in the car but you will be able to pop the bonnet.
  5. #5
    I had this on my 93, I used a bent wire coat hanger and poked it down through the hood & window and managed to flick the switch on the top of the door card up. Takes a bit of patience though!
  6. #6
    Can you open the trunk?
  7. #7
    Guys,
    Am in the same position where the manual key has stopped working in the past 24 hrs. Any help would be gratefully appreciated as I have also blocked the missus in who cant get to work. Of course every locksmith in the world seems to be busy today
  8. #8
    Saabisti
    Join Date
    Nov 2012
    Location
    London
    Posts
    132
    Hello there,
    I had the same problem a few years ago and called a breakdown service. The result being, I had two options
    A Call an AutoLocksmith. Or...
    B The Following....
    First he said, I would need to sign a disclamer, as he would need to slightly pull the drivers side window out from the top of the soft top and insert a long hooked wire down to the bonnet release in the drivers foot well to release the bonnet catch, so he could charge the battery, and the window could shatter in the process.
    I decided to let him take this route instead of the Auto Locksmith, and he managed to release the bonnet catch without the window shattering.
    He then gave the battery a boost, and the central locking worked again.
    I can't understand why the key wouldn't work manually, something about the central locking needing power.
  9. Remove Advertisements
+ Reply to Thread
  1. Dead Battery
    By webbetty in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 06-23-2008, 11:18 PM
  2. DEAD BATTERY NOW CAN`T UNLOCK DOORS OR BOOT
    By TheBigYin in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 11-22-2007, 10:32 PM
  3. dead battery
    By scminks in forum Saab 9000 (1984 - 1998)
    Last Post: 01-13-2006, 04:45 PM
  4. Dead battery
    By delfegi1 in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 05-15-2004, 04:38 PM
  5. dead battery
    By more_8 in forum Saab 9000 (1984 - 1998)
    Last Post: 06-20-2003, 05:24 AM
