saab 9-3 tid won't start
+ Reply to Thread
Results 1 to 9 of 9
Thread: saab 9-3 tid won't start
  1. #1
    my saab 9-3 tid vector is turning over but won't fire up ?? any input before i take to dealers
  2. #2
    Saabisti
    Join Date
    Sep 2012
    Location
    Scottish Highlands (where ebay rips you off)
    Posts
    117
    Re: saab 9-3 tid won't start
    What year? Any symptoms 1st? When it is turning over, is there any smoke from the exhaust?
    Lots of questions, but it may narrow down the cause....
  3. #3
    it's on a 05 plate had jump leads on car to give extra power
    the car try's turning over soon has u turn key no smoke
    but i have noticed a little oil under car
  4. #4
    Saabisti
    Join Date
    Sep 2012
    Location
    Posts
    117
    OK, if there is no smoke, then there is no combustion, ergo no fuel.
    Check the immobilizer first, it may be it has shut down.
    I would check the injectors are getting fuel. You'll need a code reader to check for stored fault codes.
    Possible the electric lift pump has malfunctioned or a relay or fuse.
    First, get a friend to turn the ignition (but not to turn the engine over) to on where all the dash lights come on whilst you listen near the fuel pipes for a hum or a whirr. Also, look to see or even feel if the pipes quiver when the pump is supposed to deliver fuel to the main mechanical pump.
    If that happens, then there may be a fault with the mechanical pump.
    There are so many reasons the engine wont start....
  5. #5
    ok ill check the pumps/injectors in morning see if i have any joy
    how would u find out if the immobilizer stopped working ??
  6. #6
    Regular Saab Guy inditime's Avatar
    Join Date
    Aug 2012
    Location
    Nr St Neots
    Posts
    78
    Try removing one or two of the vacuum hoses that go to the vacuum solenoids on the side of the battery box. I did this to get mine started once. Sorry for the vague description, if you post a picture of youre engine bay Ill arrow the hoses for you. It turned out to be a vacuum solenoid issue stopped my 04 9-3 SS from starting. I have posted this before a couple of weeks ago, so give it a go.
    Current:
    Saab 9-3 Vector 150 Sportwagon
    Jaguar XK Coupe
    Landy Disco
    Past:
    Saab 9-3 SS
    Saab 9-3 Classic
    Saab 9000
    Saab 900 Classic
  7. #7
    Saab Newbie
    Join Date
    Sep 2012
    Location
    Aldershot, UK
    Posts
    5
    I absolutely guarantee that the Diesel Particulate Filter is clogged to hell. This is what needs cleaning/replacing or your car isn't going anywhere. Same thing happened to my car when it belonged to my parents.
  8. #8
    Saabisti
    Join Date
    Sep 2012
    Location
    Posts
    117
    Quote Originally Posted by bval View Post
    Surely a warning would flag up to suggest this is the problem?
    On saying that a blocked exhaust will almost certainly prevent starting. But in my experience, there will always be a start then a stoppage in such a case?!
    Am happy to be proved wrong though. I don't know everything
  9. #9
    hi all thanks for reply's been plugged in coming up with fault low pressure to fuel rail .... had injector feed off no diesel coming so narrowed it down to fuel pump ... been told to try the sensor next to pump first any point or just jump in deep end and but new pump ??
  10. Remove Advertisements
+ Reply to Thread
  1. Saab 93 won't start
    By bus in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 06-18-2008, 10:06 AM
  2. Saab 9-3 through a belt and now won't start, replaced the belt but won't start now
    By welshwizard in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 12-16-2007, 07:09 AM
  3. SAAB will not start
    By DANNXX in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 03-02-2006, 08:19 PM
  4. Help my Saab won't start
    By Kagey in forum Saab 9000 (1984 - 1998)
    Last Post: 07-21-2004, 01:15 PM
  5. Help my Saab won't start
