saab 93 aero low revs
Results 1 to 14 of 14
Thread: saab 93 aero low revs
    Aug 2012
    4
    Blog Entries
    1
    hi my 03 saab 93 aero 2.0t sport saloon is running low on revs but it drives ok , does anyone know why this might be.
    cheers
    Super Moderator aerojon's Avatar
    cheshire
    2,570
    Re: saab 93 aero low revs
    welcome to SS..
    running low on revs,more specifics if possible..
    Aug 2012
    4
    Blog Entries
    1
    its also got a problem saying air flow cause we took it down the garage he hook it up to the machine and it said air flow
    Aug 2012
    4
    Blog Entries
    1
    when idle its about 800 revs
    cheshire
    2,570
    Quote Originally Posted by psal View Post
    What was the fault code?
    800 is about right for idle..
    Aug 2012
    4
    Blog Entries
    1
    not sure i will ask later thanks for ur help m8 i will text u the fault code when i can
    Super Moderator jezz1's Avatar
    Jun 2009
    South East UK
    1,178
    Does the low idle cause vibration, or is it ok?
    hi , i've got an se which has extreemly low revsabout 600 at best when starting then once its warmed up its idleing to high arround 1200-1500, it drives fine and there is no vibration except what you would expect from a cold engin getting going without a choke, noone seems to know why or what i need to sort this out, does anyone else have thes problems, i'm new to this site so i'm probably posting this in the wrong place but the other posts sounded like they could be related.
    Saab Anorak
    Aug 2011
    uk
    854
    Quote Originally Posted by emmett View Post
    hi emmett welcome to ss
    a few more specifics on your vehicle would be great, but could be one of the sensors that control vehicle some that are relative cheap and some not..........so to try and point you in right direction please give full details of vehicle.
    a few basic things you could try first are check/clean
    throttle body...............clean with carb or brake cleaner check operation of butterfly
    maf sensor ...................spray with electrical contact cleaner and allow spray to fully evaporate beffore refit
    air filter ..................... check renew if required
    idle control valve (IAT).............check pipes to clean valve brake/carb cleaner
    map sensor......................clean same as maf
    further info on the above is available if you search this site or you get stuck.....maybe worth posting new thread on your issue
    these are just a few relitave easy jobs to carry out without going in to any major expense to see if it improves your problem then you can go from there other components etc
    if i was you i would post up a new thread rather than trying to revive an old one
    Hi Emmett.
    Firstly i would look at the plugs, need to be the right grade of NGK and NGK only - the DI (coil pack) is designed to work with NGK plugs only. Aeros are hard on thier plugs.
    We do not stop playing because we grow old; We grow old because we stop playing.
    Saab Anorak
    Aug 2011
    uk
    854
    Quote Originally Posted by the zohan View Post
    Hi Emmett.
    strange one this any one ever got to the bottom of it ? ...........i know iridium plugs can cause issues on different engines but the fact that the b207 factory fit ngk plugs cant be x referenced with say another leading manufacturer denso or bosch of the same spec..... the engine can throw a fit lol its as if it has a human mind
    Saab Anorak
    Aug 2011
    uk
    854
    ^^^^^ i used human mind because it reminded me of my wife/kids dont want that make....want that one lol
    Jun 2009
    South East UK
    1,178
    When the engine is cold, and the revs are too low, does switching on the air conditioning seem to make it better?
    I would defo say air flow meter as this or throttle position sensor cheapest option is air flo meter simple to change aswel
  16. Remove Advertisements
  1. Power loss at low revs-Saab Vector Sport 93 150bhp
    By ChrisR57 in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 10-18-2012, 03:50 PM
  2. Saab 900S '97 stalling both at idle and higher revs
    By omeganos in forum Help, Advice, Saabs and Motoring
    Last Post: 03-05-2012, 11:39 AM
  3. pinking in low revs - new Saab 95 owner & Luv it!
    By littleoakswsm in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 05-04-2007, 03:22 PM
  4. check engine light on aero. revs dancing any ideas ?
    By yurgin 2 in forum Saab 9000 (1984 - 1998)
    Last Post: 08-31-2004, 06:39 PM
  5. check engine light on aero. revs dancing any ideas ?
