saab 93 2008 drivers window problem - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: saab 93 2008 drivers window problem
  1. #16
    Re: saab 93 2008 drivers window problem
    Quote Originally Posted by rubble2 View Post
    Just for information, when you say you had to reset it 5 times do you mean the whole process including pulling the fuse or just the re-calibration?
    For me I didn't have to pull the fuse but maybe it would have been less attempts if I had.
  3. #17
    Ok, been having a play - this is what I have found.
    The drivers window pinch protect was not working so I pulled Fuse 5 and I could then calibrate the windows (complete with chime).
    Passenger window worked fully as I would expect, drivers window still did this odd thing where if you open it part way and then try and raise it again, it wont raise when you operate the up switch but it continues to open and it is only possible to raise it once it is fully open.
    Had another go this morning, pulled fuse, calibrated drivers window checked pinch protect on driver window - working.
    Then calibrated passenger window - pinch protect working, raises and lowers properly. Went back to drivers window and now the pinch protect has stopped working.
    I am confused
    P.S. I looked on WIS, there is an entry there on what to do if the calibration/pinch control cannot be set but when I click on it it says that this fault finding information is not available.
    If anyone has WIS could they check for me and see if it is the same for them?
    BTW car is a 2009 MY 9-3
    Sorry, my WIS only goes up to 2007.
  4. #18
    I have checked my WIS (up to 2007) and it says the same. No information.
    The calibration of the pinch protection says......
    1. Shut doors.
    2. Start car.
    3. Open window about 15cm.
    4. Close window completely, hold button for at least 1 sec after closing.
    5. Press the button and the window will auto wind down.
    6. Wait at least 1 sec.
    7. Drive window fully up holding button until sound confirms.
    I have not found a foolproof way to calibrate everything first time.
    It generally takes a few attempts to get things working and as yet I cannot figure out why.
  5. #19
    Thanks,
    Looks like I will just have to persevere
  6. #20
    I had this on my '04 Vector Conv. Both the front windows would not shut on auto, they would bounce back down to the halfway point. I would have to edge my way up with the window switch for them to close all the way. Pinch protect I think. However, my battery went flat a month ago. I was without any battery for about 1 hour while I tried to get the new one to fit the housing properly. When this was done, I connected the new battery and the windows shut on auto, and when putting the roof back up. So in short, try disconnecting the battery for a while, it might just reset the whole thing. Happy days. Shame it's so bloody wet the roof is permanently up! Cheers. Chris.
  7. #21
    Ok,
    Sorry to bang on about this but here is an update.
    Now seem to have managed to calibrate both front windows as regards pinch protect but still have this situation with the drivers window.
    This is what happens.
    I press the auto window down button and the window descends, it will continue to descend until it is fully open. If I then press the auto window up it will close again as you would expect until fully shut, however if I press auto descend as before but stop the window opening fully by lifting the 'up' switch briefly and then press the auto up the window will continue opening and I can only raise it again once it has reached the fully open position.
    The passenger window works normally when I follow the same procedure -: stop window half way down its open cycle then press auto up and the window closes fully.
    Any one shed any light please?
  8. #22
    Battery off, fuse out, door module off, still won't bloody work
    Why why why!!!!!! Arrrrrrr!
  9. Remove Advertisements
  1. 2005 saab 9-3 drivers window trim
    By aa777rob in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 07-10-2010, 10:28 PM
  2. Drivers Side Door Window problem
    By kae in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 06-08-2009, 03:38 PM
  3. 98 900 Drivers electric window problem
    By diesel in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 05-01-2008, 08:07 PM
  4. WANTED.SAAB 900.DRIVERS WINDOW.1994
    By davidhalfpenny in forum Saab Parts / Accessories, FOR SALE and WANTED
    Last Post: 11-24-2007, 04:23 PM
