saab 93 2008 drivers window problem
NEWS
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Thread: saab 93 2008 drivers window problem
  1. #1
    i have a saab 93 2008 model. the drivers window will auto go down but wont auto go up. i have tried to reset the pinch protection and pulled the fuse and and disconnected the door module but it just wont reset, its driving me insane. anyone got any ideas?
  2. Remove Advertisements
  3. #2
    Super Moderator jezz1's Avatar
    Join Date
    Jun 2009
    Location
    South East UK
    Posts
    1,178
    Re: saab 93 2008 drivers window problem
    Try lubricating the rubber seals around the window with silicon lubricant. If there's too much friction and resistance, the window mechanism will think there's an obstruction and refuse to close.
  4. #3
    I have tried this and it still won't work
  5. #4
    How are you resetting the pinch after you pulled the fuse?
  6. #5
    I am doing as the Saab manual says, when I pull the fuse and disconnect the door module the passenger window calibrates ok but the driver windows not having none of it
  7. #6
    i got the same issue for all 4 windows. however, this only started to happen when i changed my drivers door control module for all 4 windows which was from a normal saab 93 not a convertable mines a convertable... any help appreciated. sorry for hijacking the thread rather.
  8. #7
    Help help help, switch must be ok as it wouldn't work at all so I'm lost
  9. #8
    Super Moderator aerojon's Avatar
    Join Date
    Nov 2009
    Location
    cheshire
    Posts
    2,566
    is it just the drivers window that won't one touch up or all of them.
  10. #9
    Yes just the drivers window, it will not reset the pinch system. It's auto one touch goes down but will not auto one touch up. I have spent hours researching this and tried all sorts and it still won't calibrate.
  11. #10
    When you push the button you should be able to feel 2 switches.
    The first is just the normal activation and a little further in is another for the auto.
    If you have reset the window as per the SAAB manual i.e....
    Calibration is performed as follows:
    1 Close the doors.
    2 The car must be running at idling speed.
    The battery charger must not be
    connected to the car’s battery during
    calibration.
    3 Open the window fully, the button must
    be kept depressed the whole time.
    4 Close the window fully, the button must
    be kept raised the whole time and for
    approx. 1 second after the window has
    closed.
    5 Open the window fully, the button must
    be kept depressed the whole time and
    for approx. 1 second after the window
    has fully opened.
    6 Close the window fully, and keep the
    button raised until the calibration is
    confirmed with a "chime".
    Repeat steps 3-6 for the windows which
    require calibration.
    If can't feel the second switch then maybe you have a faulty unit?
    Hope this helps.
  12. #11
    I know how to do this, the passenger side calibrates fine but the drivers side will not
  13. #12
    Quote Originally Posted by APK View Post
    1 Close the doors.
    calibration.
    closed.
    has fully opened.
    Hope this helps.
    Don't want to hijack this thread but I have found that when I try this method there is no 'Chime' at the end of the process (at least there isn't one for the 30 seconds or so that I can manage to keep holding the switch in the 'up' position before acute boredom sets in.
    Having said that, all of the windows calibrate ok except for the drivers door which does the following :-
    If I press automatic down and then pull the switch up to stop the window descending before it is fully open, the window stops ok, but if I then pull the switch up again to raise the window, it continues to lower until it is fully open at which point I can auto raise the window with no further problems. This only happens on the drivers door window - any suggestions?
  14. #13
    Sorry Mike,
    Not trying to teach you to suck eggs, just making sure and giving the info for general use.
    I had to reset mine about 5 times before it started working correctly so maybe it needs a bit of luck!
  15. #14
    Sorry Mike,
    Just for information, when you say you had to reset it 5 times do you mean the whole process including pulling the fuse or just the re-calibration?
  16. #15
    Ok, been having a play - this is what I have found.
    The drivers window pinch protect was not working so I pulled Fuse 5 and I could then calibrate the windows (complete with chime).
    Passenger window worked fully as I would expect, drivers window still did this odd thing where if you open it part way and then try and raise it again, it wont raise when you operate the up switch but it continues to open and it is only possible to raise it once it is fully open.
    Had another go this morning, pulled fuse, calibrated drivers window checked pinch protect on driver window - working.
    Then calibrated passenger window - pinch protect working, raises and lowers properly. Went back to drivers window and now the pinch protect has stopped working.
    I am confused
    P.S. I looked on WIS, there is an entry there on what to do if the calibration/pinch control cannot be set but when I click on it it says that this fault finding information is not available.
    If anyone has WIS could they check for me and see if it is the same for them?
    BTW car is a 2009 MY 9-3
  17. Remove Advertisements
+ Reply to Thread
  1. 2005 saab 9-3 drivers window trim
    By aa777rob in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 07-10-2010, 10:28 PM
  2. Drivers Side Door Window problem
    By kae in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 06-08-2009, 03:38 PM
  3. 98 900 Drivers electric window problem
    By diesel in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 05-01-2008, 08:07 PM
  4. WANTED.SAAB 900.DRIVERS WINDOW.1994
    By davidhalfpenny in forum Saab Parts / Accessories, FOR SALE and WANTED
    Last Post: 11-24-2007, 04:23 PM
