Breather pipe problem
+ Reply to Thread
Results 1 to 8 of 8
Thread: Breather pipe problem
  1. #1
    Saab Junior
    Join Date
    Jul 2005
    Location
    London
    Posts
    27
    After the low oil alert went off on my 9-5 estate year 2000 I found the breather (?) pipe on the rocker box cover had split in two also the fitting for the pipe into the box came away in my hands, looks like it has left bits inside box
    Pictures attached
    Is the bust pipe responsible for the lost oil? looks to me like the car never had the pcv change?
    Any advice welcome, the other end of that pipe looks to be a long way down and very hard to get toIMG00329-20120603-1207.jpgIMG00330-20120603-1209.jpg
    Thx
  2. #2
    Re: Breather pipe problem
    Wont help the oil level but was it actually low on oil or is it actually low in oil pressure? Now the pipes are becoming brittle its defo time for the PCV kit, £41 gets you the kit but you want the supplementary kit aswell for £56. Goes without saying the bits from the broken pipes will end up in the strainer so if your keeping the car and want to know it will last you need a sump drop and clean.
  3. #3
    Saab Junior
    Join Date
    Jul 2005
    Location
    London
    Posts
    27
    Quote Originally Posted by saablee View Post
    It was very low on oil, nothing on dipstick after being stationary overnight! First time Ive seen that in 14 months of ownership
    so £96 for the pcv kit, then theres labour for sump drop and clean and to fit the pcv kit plus the cost of oil and filter, I reckon Im looking at £400 min in total dont you? This may mean the car is not worth keeping and it will be all but unsaleable, no one seems to want these gas guzzlers anymore especially as the parts are so expensive and the mpg so terrible
    I think I'm ok for bits falling into the strainer, the pipe split was so clean it was like a razor had done it. I now know the PCV nipple is supposed to look like that and has not broken.
    Maybe best for me to fix that breather pipe and change oil and filter myself and carry on. Ok it may shorten the car's life but practically speaking with 145K on the clock its probably only a matter of (short) time before something even more expensive fails on it.
    I spent 350 quid on a new clutch for my old Saab 9000 CDT and then just a month later the head gasket blew. At £800 plus estimate for the fix it was all over and the car was sadly scrapped.
    Dont want to be pouring money down a hole and another year's use out of the car would do me in relation to the initial investment
    n
  4. #4
    i've heard of fully serviced supremely maintained engines giving up and abused engines running forever! Change the PCV and get some fully synth oil in there and what will be will be
  5. #5
    Saab Junior
    Join Date
    Jul 2005
    Location
    London
    Posts
    27
    Yes but now I see cream on my dipstick since putting in few litres so I could move it down road. Could be moisture getting in from air or could be headgasket. If its the latter then it will be a bad move to spend money on the pcv
    Oh and ive also spotted the check valve has broken, thats another £15! Grrrr
  6. #6
    If one pipe has broke up then they will all be due and the PCV upgrade is a must regardless. You cant really diagnose anything till all the pipes are connected and working correctly so would do that first and then see whats going on.
  7. #7
    Saab Junior
    Join Date
    Jul 2005
    Location
    London
    Posts
    27
    I know I know, but it's a lot of money that I could do without spending. Ill see what my usual garage will quote.
    Be a bitch to do the pcv and then find the headgasket was gone!
    n
  8. #8
    Saab Newbie
    Join Date
    Feb 2009
    Location
    Nottingham UK
    Posts
    23
    Can you tell me what PCV stands for? I'm having a bit of trouble with broken connections on various bits of pipework on my 2.3 HOT Aero so would like more info. Thanks
  9. Remove Advertisements
+ Reply to Thread
  1. Auto gearbox breather pipe
    By Bloxie in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 04-15-2009, 05:16 PM
  2. Breather Pipe replaced
    By madnutter in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 08-03-2005, 06:15 PM
  3. SOME SORT OF BREATHER PIPE
    By patbhoy in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 02-18-2005, 04:16 AM
  4. Breather Pipe
    By ms08 in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 05-08-2003, 11:04 AM
