traction control failure & left brake light failure
NEWS
+ Reply to Thread
Results 1 to 11 of 11
Thread: traction control failure & left brake light failure
  1. #1
    Super Moderator haloweenhamster's Avatar
    Join Date
    Mar 2009
    Location
    Bletchley frequent Birmingham & Northampton
    Posts
    1,327
    9-3 1.8i 54 plate
    hi went for a drive yesterday and left brake light failure came up on the display so I stopped and checked and it is working fine half hour later brake and abs warning lights come on along with traction control failure on the display and the speedo & rev counter stopped working so I stopped turned the ignition off and attempted to restart and the engine didn't even turn over, I left it for 15 mins and it started but messages and lights have been coming back intermittently
    tech 2
    cim p bus
    left brake light circuit open
    anyone know of anything that could cause this or have a copy of WIS they want to sell?
    cheers
  2. Remove Advertisements
  3. #2
    Re: traction control failure & left brake light failure
    It could be a sign of a failing alternator - they often cause all sorts of electrical gremlins. Get the alternator's output checked.
  4. #3
    Join Date
    Mar 2009
    Location
    Posts
    1,327
    cheers I'll check voltages in a bit
    the brake light I found a thread saying that the tail light takes over the brake light if it fails and surely enough the bulb had gone just couldn't tell with functional test
  5. #4
    Join Date
    Mar 2009
    Location
    Posts
    1,327
    just checked
    batt 12.35v
    alt 13.82v with everything poss off
    am i right in thinking the it should be 14.2-14.5v?
  6. #5
    Join Date
    Nov 2009
    Location
    Cheshire.Uk
    Posts
    4,767
    Quote Originally Posted by haloweenhamster View Post
    yes you are..
  7. #6
    Shame on those who say I'm just a pretty face...
  8. #7
    Join Date
    Mar 2009
    Location
    Posts
    1,327
    Just done a load test (all lights, heater full, fan full) 12.9v with engine running
    cheers muchly for the assistance I'm ordering an alternator asap
  9. #8
    Join Date
    Mar 2009
    Location
    Posts
    1,327
    Hi just wondering if anyone knows if the alternators are interchangeable ie the 120a one fitted to a 140a or more from a bigger engine 9-3
  10. #9
    Join Date
    Mar 2009
    Location
    Posts
    1,327
    Replaced the alternator and faults stayed (other than low voltage) and it got to the point that the engine light came on aswell and had no power (had to stop on m1) so called AA his tool said no faults, tech2 said 19 faults all bus related all on p bus
    So on tech2 I removed the CIM then added it reprogramming the keys in the process
    in 3 days no faults so far so alls good
    might be worth a try for others if they have traction control failure
    My CIM is only 4 years old after having airbag failure which saab replaced the CIM for
  11. #10
    Excuse my ignorance on this folks but whats a "CIM"
    Bolton lad living on the South Coast
    Saab 93 1.9 Tid Cabriolet 09 Plate
  12. #11
    Join Date
    Nov 2009
    Location
    Cheshire.Uk
    Posts
    4,767
    CIM=Column Intergrated Module..
    it sits behind the steering wheel,it's what the wiper & indicator stalks are in,also controls steering lock,has sensors inside & part of the security system..
  13. Remove Advertisements
+ Reply to Thread
  1. Stability control failure, abs malfunction & traction control failure
    By alanaberdeen in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 08-07-2014, 12:47 AM
  2. traction control failure stability failure
    By bigjazz70 in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 06-30-2012, 12:36 PM
  3. traction Control failure
    By 02920al in forum Help, Advice, Saabs and Motoring
    Last Post: 11-14-2011, 12:14 PM
  4. Replies: 1
    Last Post: 10-24-2011, 01:47 PM
  5. traction control failure stability failure
    By bigjazz70 in forum Saab Recommendations
    Last Post: 12-31-1969, 08:00 PM
