SAAB 9-5 non start problem
+ Reply to Thread
Results 1 to 3 of 3
Thread: SAAB 9-5 non start problem
  1. #1
    Saab Newbie
    Join Date
    Dec 2011
    Location
    Halifax, West Yorkshire
    Posts
    2
    Hi Guys,
    Firstly hello everyone!! Sorry for this being my first post. I do a lot of lurking, but I don't tend to register a lot of the time but now I am here and I am hoping that you might be able to help me with our family daily, Digger as he is named.
    Digger is a 1999 SAAB 9-5 2.3 LPT (with 201,100 miles on the clock) and few days ago I was changing the pollen filter, so I had the glove box out. I changed out the filter and put everything back, I moved up to the scuttle panel and removed the wiper linkage to inspect the blower motor. The car was starting before I did any of this work.
    All this was returned as I found it, and I sat in the car and tried to start it. Crank, crank, crank..... no fire up. It had been running earlier that morning.
    If someone had told me this same scenario I would be almost 99% sure that what ever they had fiddled with would be the root cause of the non start. I promise hand on heart that I have checked every wire in the areas I have been in. The only other thing to note really is that I have the bonnet up for quite a long time and I had the ignition on for a long period.
    There are other complications, this car runs and ALDESA RSI+ lpg system, this is hooked directly to the ECU and for some reason this prevents me pulling codes from the car with an ODB reader. Why I do not know?
    Now onto what I have checked and what I think I know....
    There is no spark, there is no prime sound with the fuel pump. The main relay has 2 12v feeds and good earths, so this tells me that the ECU is switching the relay? The injectors are not getting any power.
    If I give a 12v feed to the lower connection on fuse 19 (fuel pump fuse) I can run the pump and I can get fuel to the schrieder valve on the fuel rail.
    I have swapped over the fuel pump relay with wiper relay and tested it, so I know the relays are ok.
    I have even done a quick check on the CPS and it is showing a varying resistance as the engine is cranked, but then again my limited knowledge tells me that this wouldn't cause the fuel pump not to run.
    I have checked EVERY fuse and relay that I can find. I have locked and unlocked the doors, left the battery off over night just to try and do a reset.
    I have one key with the car and that has always started it, I don't get any warning messages other than TEST THE BRAKES on the SID.
    It is seriously acting as if a fuel pump cut off or crash sensor has gone off and as far as I know this model doesn't have one?
    Some other things to note:- The battery has full charge, I have checked the Earth to the inlet manifold and that was loose. Great I thought, got it. Tightened it and nothing!
    I have run out of ideas, I don't really know where to go next. I am open to ANY ideas you may have, even if it means me going back and checking where I have been before. Maybe there is something in the areas I have been that needs extra special attention??
    Thanks in advance for any help you might be able to give me.
    Jay
  2. #2
    Saab Newbie
    Join Date
    Dec 2011
    Location
    Berkshire, UK
    Posts
    5
    Re: SAAB 9-5 non start problem
    HI, unless someone has already said this, otherwise it sounds like it could be the coil pack.
    Ive had the same problem, although mine has a tendency to stall whilst driving, and not restart!
    Oh and Im currently in the process of changing no. 4 / 5 coilpacks in as many months!!
  3. #3
    Just to be sure its not a fuel problem u should spray carb cleaner in one of the vacuum opening and try cranking. if it starts even for a second u know everything is working except u dont have fuel pressure. if it still just cranks with no sign of starting then u have some serious troubleshooting to do my friend. GOOD LUCK
  4. Remove Advertisements
+ Reply to Thread
  1. 95 Won't start - DI problem?
    By phcx in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 03-08-2011, 08:10 PM
  2. 1993 SAAB 9000CD Cold start problem.
    By something in forum Saab 9000 (1984 - 1998)
    Last Post: 02-07-2011, 02:11 AM
  3. Another (no) start problem
    By berkbs in forum Saab 9000 (1984 - 1998)
    Last Post: 12-07-2007, 01:27 PM
  4. hot start problem again
    By gacsalyi in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 08-13-2004, 07:28 PM
  5. start problem
    Last Post: 05-19-2004, 04:52 PM
