fault code p1312
NEWS
+ Reply to Thread
Results 1 to 6 of 6
Thread: fault code p1312
  1. #1
    i have been told the code of p1312 for saab 93 aero 2003 is that of the throttle body does anyone know any different ? thanks again
  2. Remove Advertisements
  3. #2
    Join Date
    Nov 2009
    Location
    Cheshire.Uk
    Posts
    4,784
    Post
    no,check your plugs are clean & not sooted up,from memory think that code is specfic for the ionization module failure,don't quote me on that..
    My 9-3 audio,2 x cd changers,aux-in & Bluetooth audio streaming..
    Is still running Factory oe coils with a tune..
  4. #3
    no,check your plugs are clean & not sooted up,from memory think that code is specfic for the ionization module failure,don't quote me on that.. [/b]
    what do i need to do to fix this problem as the car went into limp home mode and just judders after 4 on the rev counter thanks
  5. #4
    Wastegate
    Join Date
    Sep 2000
    Location
    Mulbarton, was Deepest Mid Norfolk
    Posts
    8,945
    P1312 is misfire on cyl 1 or 2
    P1334 is misfire on cyl 3 or 4
    Check/Gap/clean or replace the plugs 1st.
    If that does not fix it, then try another DI
    Judder over 4000rpm sounds like misfire under boost.
  6. #5
    Just had that code in my Aero, though there were no other symptoms. Dealer told me I needed a new DI, and I asked for the plugs to be done at the same time.
    I wouldn't delay, as if the DI lets go on the move it can take out the cat.
  7. #6
    thanks for the info turns out its only the plugs ...........
  8. Remove Advertisements
+ Reply to Thread
  1. CEL code P1312
    By webbetty in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 12-10-2014, 01:16 PM
  2. fault code p1312
    By rubberman in forum Help, Advice, Saabs and Motoring
    Last Post: 06-28-2011, 12:14 PM
  3. fault code
    By traviski in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 09-05-2010, 12:50 PM
  4. fault code 11
    By cjmacd in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 10-22-2009, 02:30 PM
  5. Check Engine Light On. Fault code reader will not read fault.
    By mike_j in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 01-24-2008, 09:30 AM
