Hi, I hope someone can help.
I am driving a 2005 Saab 9-3 TiD 150 with 59k miles on the clock.
Several weeks ago I had the dpf replaced and after about 2 weeks the engine light came on. This showed up as a dpf sensor fault which I have just replaced. After driving about 2 miles the engine light came back on and I limped home (again)! The egr valve was replaced in January 2009. I have checked and cleaned (not much soot on the valve and operating freely).
After replacing the dpf I got some power back, but it still felt as if something was holding it back (turbo seems ok).
Is it possible that a choked inlet manifold would result in a dpf sensor fault?
Any ideas welcome.
Had the same problem myself. Could be inlert manifold blocked, swirl valves or throttle body to start with.
It could be a number of things. What was the code?
I'm not sure what the code number was, but the mechanic said it came up as a dpf sensor fault.
Does the sensor check for high and low pressure differential or just high pressure?
Re: dpf, pressure sensor or inlet manifold problem?
hi everybody, i have a saab 9-3 150bhp vector sport engine code z19dth, i had the exact same problem with my dpf, infact it was a P1901 code, which is the differential pressure sensor. i purchased a new sensor from ebay and it cleared it up, the engine light stayed off, and sure enough the car was back to normal after a couple of weeks. http://www.ebay.co.uk/itm/Saab-9-3-d...item27cad16a9f have a look at the listing on ebay..
By Holski in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
Last Post: 07-06-2011, 04:28 AM
By ukretro in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
Last Post: 05-25-2011, 10:40 AM
By fezfam12345 in forum Help, Advice, Saabs and Motoring
Last Post: 10-23-2010, 02:41 PM
By dorianj in forum Classic Saab 9-5 (1997 - 2009)
Last Post: 06-07-2010, 03:59 PM
By buzz1690 in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
Last Post: 01-13-2009, 03:32 PM
- You may not post replies
- You may not edit your posts
Forum Rules
