Hi, looking for help with another problem on our 1995 Aero.
When we got the car a year ago, the blower fan for the heater was very noisy when running, particularly when running at maximum speed. Within the last few days, there were two occasions when the noise became extremely loud indeed - a rumbling screech - and on the second such occasion the fan would not turn off even with the whole ACC set to "Off". When the fan finally did stop working, after I killed the ignition, it then wouldn't come on again at all. Just what we don't need now we're coming into winter, with frosty windscreens and cold weather!
We're clear that the problem must be that the blower fan motor has worn out, and now needs to be replaced. We know where it is, having attempted (and failed) to salvage the whole unit from a now-departed donor 9000 a few months ago, and since then we've found a set of instructions on the web for changing the motor. However, we would really appreciate some advice from someone who has actually done the job!
When we tried to salvage the fan from the donor car we had. we just could not work out how to remove the big black plastic fan housing from the car itself - we'd taken off the heater hoses, removed the firewall, etc, to make space, had removed every screw, spring and clip we could see, and it still would not come free. In the end the housing broke, at which point we gave up trying. Is the fan housing held in place from the front, requiring the dashboard to be stripped out for the removal of screws or clips, or should it be possible to remove it working only from within the engine compartment? And if so, what's the trick?
Once we have got the fan housing removed, the downloaded instructions are not very clear about what we are going to find inside it. Do we just need a new fan motor, or are there separate bearings that also need to be replaced? I'm confident we can handle any reasonably straightforward mechanical disassembly/assembly work - we know what we're doing with that sort of thing, but as I've said when we tried before to remove one of these fan housing from a car, we just couldn't do it.
Help!
Help!
