Brake Light/Rear Light Failure 2006 Aero salloon
NEWS
+ Reply to Thread
Results 1 to 4 of 4
Thread: Brake Light/Rear Light Failure 2006 Aero salloon
  1. #1
    Hi there,
    I've just got a warning message about my brake lights/rear lights, There's something slightly strange going on in that with the lights off, the brake lights seem to work fine, but opperate the side lights (little front bulbs) at the same time as the brake lights come off.....
    When I turn the lights on, the high level brake light comes on, albeit dimly, that gets brighter when the brakes are activated...
    I've checked fuses and all seem fine in the dash board fuse box... any other thoughts?
    Greg
  2. Remove Advertisements
  3. #2
    Regular Saab Guy
    Join Date
    Oct 2002
    Location
    Felixstowe
    Posts
    88
    Hi there, check out the broken wires in boot hinge topic pinned above. It gets them all eventually!
  4. #3
    Thanks for the reply, I've just checked them, and they all seem fine except some wore showing on the yellow/green cable. The rest look in good nick, is there anything else it could be?
    Greg
  5. #4
    Saab Afficionado
    Join Date
    Mar 2008
    Location
    Wiltshire
    Posts
    1,599
    Make sure you pull the rubber boots back at either end to check the cables.
    If no sign of breaks here then try taking out the brake light bulbs asnd cleaning the sockets they go into to make sure you have a good contact, possibly replace both bulbs as well. I had something similar on a Mondeo a few years ago and it was an earth loop caused by poor connections in the bulb holders.
  6. Remove Advertisements
+ Reply to Thread
  1. Replies: 1
    Last Post: 10-24-2011, 01:47 PM
  2. ABS light, brake light, TC failure light coming on intermittently
    By rjmeer in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 11-26-2009, 07:35 AM
  3. Rear Fog light / high level brake light problems
    By Tariq in forum Saab 9000 (1984 - 1998)
    Last Post: 11-03-2009, 02:46 PM
  4. Brake Light Failure
    By indiekid in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 01-22-2009, 01:16 PM
  5. Brake Light Failure
    By sgould in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 08-18-2002, 05:02 PM
