Torque Arm Access
NEWS
+ Reply to Thread
Results 1 to 6 of 6
Thread: Torque Arm Access
  1. #1
    Saab Junior
    Join Date
    Aug 2005
    Location
    Bournemouth, Dorset.
    Posts
    26
    I’m going to replace the bushes on the rear torque arms (with Superflex bushes), & once the job is done the final tightening of the torque arms obviously needs to be done with the wheels back on the ground. My question is… how do you access the bolts to do this once the cars back on terra firma – especially when mine has a deliberately low ride height? Are there any tricks, or are they relatively easy to access?
    TAA
  2. Remove Advertisements
  3. #2
    Saab Afficionado
    Join Date
    Jun 2000
    Location
    Forfar,Angus Scotland
    Posts
    1,242
    A pair of ramps?
  4. #3
    Full throttle mark e's Avatar
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    Thinking out of the box... could you use a pair of axle stands under the end of each trailing arm set at a height that corresponds to "normal" distance off the ground?
  5. #4
    Saab Junior
    Join Date
    Aug 2005
    Location
    Posts
    26
    Ah, good point. Wheels don't actually have to be on, axle just has to be where it would be if they where.
    I thought about ramps. But don't own any, nor know anyone who does. Might be the time to invest. Can't be as expensive as those polyurethane bushes. Certainly not the front lower wishbones from Powerflex.... yeesh!
    2 possibilities...
    Taa muchly
  6. #5
    Saab Afficionado
    Join Date
    Dec 2007
    Location
    Stockholm, Sweden
    Posts
    1,775
    If you're using PowerFlex bushes then I don't think it matters if the suspension is loaded up or not. The central metal sleeve can rotate freely in the bush (and it's greased to allow that) whereas original bushes (being in one piece) don't allow for any 'extra' rotation which is why they need to be tightened up when the suspension is in its 'normal' resting position.
  7. #6
    Saab Junior
    Join Date
    Aug 2005
    Location
    Posts
    26
    If you're using PowerFlex bushes then I don't think it matters if the suspension is loaded up or not. The central metal sleeve can rotate freely in the bush (and it's greased to allow that) whereas original bushes (being in one piece) don't allow for any 'extra' rotation which is why they need to be tightened up when the suspension is in its 'normal' resting position.[/b]
    Of course! Excellent point, thanks Super. Seems I need to buy a thinking cap, not ramps.
  8. Remove Advertisements
+ Reply to Thread
  1. Access Denied
    By mikeloadsasaabs in forum Customer Service Desk
    Last Post: 09-21-2005, 01:43 PM
  2. Fan motor access????????
    By rob1693 in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 10-15-2004, 10:30 AM
  3. MS Access
    By scrofts007 in forum Help, Advice, Saabs and Motoring
    Last Post: 11-24-2003, 04:53 PM
  4. PDA access
    By mcwill in forum Customer Service Desk
    Last Post: 11-08-2002, 10:21 PM
