Serious CLUNK and jerk going into Drive (Automatic Aero)
NEWS
+ Reply to Thread
Results 1 to 5 of 5
Thread: Serious CLUNK and jerk going into Drive (Automatic Aero)
  1. #1
    Hi,
    I have just done an automatic oil change. It didn't seem that bad...black, but still fluid...
    Having said that, I am still getting an almighty CLUNK and jerk from the car moving into Drive.
    For example, If I move from P to N to R, no problems, smooth as a whistle.
    If I move from Drive to Revere or Neutral, smooth as a whistle.
    If I move from anything into Drive, there is a distinctive pause of about 1/2 a second to a second and then an almighty CLUNK and the whole car JERKS (foot on break, so doesn't go anywhere)...I mean, really jerks.
    It's almost like the car wants to GO and jerks forward.
    Changing gears while driving are smooth enough but can occasionally be slightly jerking moving down through gears when driving slow.
    Any ideas?
    Thanks,
    Anthony
  2. Remove Advertisements
  3. #2
    Was it doing this before the oil change?
  4. #3
    Full throttle
    Join Date
    Jan 2002
    Posts
    16,524
    This sounds like my old Aero - 2002. I sold it on and the current owner has, I understand, done a full flush of the fluid and cured the problem.
    I was told that there is a weakness with some springs in the valve block. If this is so, then a full fluid flush has masked the problem for now.
    You can only drain about 40% of the fluid through the drain plug, so you need to do 3 or 4 changes with a drive in between to actually change about 80%.
    I think there's a more complex way of draining it all, but I'm not sure how this is done.
  5. #4
    I think there's a more complex way of draining it all, but I'm not sure how this is done.[/b]
    Hi,
    I have done a 4 litre change and things seem to be better (not perfect). I plan on doing another one next weekend and see how it goes...
    The problem occurred before the oil change, hence why I did the oil change...It took a few miles to settle, but it does seem to have improved.
    Thanks,
    Anthony
  6. #5
    Saab Afficionado robertson.a's Avatar
    Join Date
    Aug 2007
    Location
    Blackburn
    Posts
    1,590
    My '02 Aero was starting to exactly the same as yours, but not as severe. I did a series of flushes and it is now a dream to drive. Particularly from R back into D, where it was very unsettled and late. Gear changes are now very smooth. Disconnect the battery too after you do the final flush, take it for a smooth gentle drive and let the car 'reset'. It will then need to learn your new change points over the next 100kms or so.
  7. Remove Advertisements
+ Reply to Thread
  1. 02 9-5 aero automatic
    By Groovephase in forum Previous model ranges, FOR SALE and WANTED
    Last Post: 04-12-2011, 07:29 AM
  2. DEPRESSED NEWBIE WITH 9-5 AUTO GEARBOX CLUNK WHEN ENTERING DRIVE
    By jamie95hot in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 05-13-2010, 07:35 AM
  3. Service theft alarm and auto jerk
    By David Martin in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 05-27-2008, 12:41 PM
  4. Zero throtle Jerk at 1500rpm
    By jrichard in forum Saab 9000 (1984 - 1998)
    Last Post: 11-25-2005, 03:41 PM
  5. Re: Hesitation or clunk on 9-5 Aero Estate
    By sgould in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 09-02-2005, 04:39 PM
