Z19DTH won't rev past 2,000 & no power, p0100
NEWS
+ Reply to Thread
Results 1 to 5 of 5
Thread: Z19DTH won't rev past 2,000 & no power, p0100
  1. #1
    Saab Newbie
    Join Date
    Mar 2003
    Location
    Nottingham, UK
    Posts
    12
    It's the 150hp on a 2005 9-3 TID.
    It has:
    Total number of fault codes: 2
    P0100 - Mass Or Volume Air Flow Circuit Malfunction
    (08) - Present
    P0100 - Intake Air Temperature Sensor Circuit Malfunction
    (21) - Present
    I'm not used to Saab and the fault codes are a bit nondescript (I'm used to short to plus/short to ground/signal too low/inplausable signal etc on VW/Audi codes) and hoping if someone can tell me if the IAT is in the MAF or the MAP and if MAP where it is.
    I was okay till parked up for a couple o months I'm told, top speed is now about 26mph on a flat. Start/Idle is fine. Unplug MAF and same codes, same 2,000rpm max.
    Appreciate your thoughts!
    Greg.
  2. Remove Advertisements
  3. #2
    Join Date
    Nov 2009
    Location
    Cheshire.Uk
    Posts
    4,783
    check for leaks/ split hoses on vacuum & intercooler pipes...
    Even loose pipes aswell
    My 9-3 audio,2 x cd changers,aux-in & Bluetooth audio streaming..
    Is still running Factory oe coils with a tune..
  4. #3
    Had a similar problem a few years back on a petrol BMW. After a faultless code reading it turned out that the Catalytic converter had collapsed & was clogging the exhaust. The back pressure created prevented the car revving much more than 2500 rpm.
  5. #4
    Checked on TIS2WEB for you and found this regarding the p0100/8a code.
    Mass Air Circuit Malfunction
    Fault symptom
    Fault indicator lamp (for further information see WIS Fault diagnosis, general)
    Performance loss.
    On-board diagnosis
    Type of diagnosis:
    Continuous
    Enable criteria:
    Ignition ON.
    Fault criteria:
    Short-circuit to B+/ground or open-circuit.
    System reaction to a fault:
    Limp Home, fuel limitation.
    EGR turned off in case of fault.
    OK report:
    Input conditions fulfilled without a fault reported.
    Checking the wiring harness
    • Faults in the control module female connector can be the cause of the DTC. Check the connector with respect to oxidation, depressed pins and pin clamping force.
    • Move the wiring harness at several spots and in several directions to reveal intermittent breaks and short-circuits. Check switches, connectors and crimp connections for oxidation, retracted pins and pin clamping force.
    Diagnostic help
    Diagnosis regards:
    Functions in the diagnostic tool related to the fault:
    Test value:
    Mass Air Flow Sensor
    (See also description of readings/activations in diagnostic tool)
    This is for the P0100/21.
    Mass Air Flow Sensor, Air Temperature Signal, Open/Short
    Fault symptom
    Performance loss.
    On-board diagnosis
    Type of diagnosis:
    Continuous
    Enable criteria:
    Ignition ON.
    Fault criteria:
    Conditions above must be fulfilled for at least 0.6 s
    Limp Home, engine torque limitation.
    Hope these help.
    Kenny.
  6. #5
    Saab Newbie
    Join Date
    Mar 2003
    Location
    Nottingham, UK
    Posts
    12
    Thanks guys.
    It was the MAF.
    Cheers, Greg.
  7. Remove Advertisements
+ Reply to Thread
  1. z19dth oil filter where to buy ?
    By billyboy in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 12-04-2014, 02:34 AM
  2. 57 plate facelift 1.9 z19dth gm brake parts
    Last Post: 11-14-2010, 10:45 AM
  3. Z19DTH Inlet Manifold Replacement
    By saab___tech in forum Saab Recommendations
    Last Post: 11-16-2009, 07:06 AM
  4. mass air flow P0100
    By Jimodoherty in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 10-13-2004, 06:23 AM
  5. past recalls
    By gundam_007 in forum Saab 9000 (1984 - 1998)
    Last Post: 08-18-2003, 12:54 PM
