Clutch Bleed/ Gear Oil Change
NEWS
+ Reply to Thread
Results 1 to 3 of 3
Thread: Clutch Bleed/ Gear Oil Change
  1. #1
    Saab Fan ledge1970's Avatar
    Join Date
    May 2006
    Location
    Southend on Sea
    Posts
    58
    Sorry if this information has been given before, I have searched the forum but not been able to uncover a specific answer so wondered if someone could help?
    After sitting for a while I think the clutch needs a bleed as the biting point is sitting quite low. I am not sure exactly where the bleed point is, can anyone point me in the right direction and advise any precautions to take please? I have bled the brakes but not the clutch before.
    Also, I wish to change the gearbox oil this weekend. I would prefer to drain it rather than siphon it. Mine is the model without the drain plug. Is it simply a case of removing the plate on the side of the box where the dipstick is (near the exhaust manifold), and just draining and re-filling once I have put the section back?
    Any information much appreciated.
  2. Remove Advertisements
  3. #2
    bleed nipple is by the slave cylinder, think on the nearside. You will not completely empty the box unless to syphon
  4. #3
    can anyone ... advise any precautions to take please?[/b]
    There's a serious risk to the master cylinder, since bleeding it moves it through a wider range of movement - a borderline cylinder will take that opportunity to give up the ghost. Mine did...
    It's not the end of the world - they're not expensive, they're not difficult to change, and it's a DAMN sight better to have it go in your drive/garage than at the traffic lights in the peeing rain when you're already late to be somewhere!
  5. Remove Advertisements
+ Reply to Thread
  1. Clutch Bleed Nipple Cracked
    By rjchalklin in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 06-07-2009, 05:16 PM
  2. Gear Change
    By tahir in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 05-18-2006, 04:54 AM
  3. Clutch Bleed TCS light on
    By deebel in forum Saab 9000 (1984 - 1998)
    Last Post: 05-26-2005, 03:57 PM
  4. Clutch Bleed TCS light on
  5. Gear change - 3.0 TiD in particular
    By jw in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 03-24-2005, 07:02 AM
