ABS light, brake light, TC failure light coming on intermittently
NEWS
+ Reply to Thread
Results 1 to 4 of 4
Thread: ABS light, brake light, TC failure light coming on intermittently
  1. #1
    Hi guys,
    I've been having this issue with my 93 2.2 tid recently. On some journeys the ABS, Brake and TC Failure picture light up. The speedo and rev counter will freeze every time these lights come on. The light do usually go off within a few seconds but there have been occasions where they can stay on for prolonged periods of time. If the car is turned off when these lights are on it wont start up until I lock/unlock the car a few times. There have also been a few occasions where all these light will go off and the message of traction control failure appears but the speedo and rev counter will work normally when this happens. Does anyone have any ideas as I cant think of what on earth could be causing this problem. The only work thats recently been done to the car is replacing its EGR valve but I doubt this could be causing the issue? Any ideas would be greatly appreciated.
    Thanks in advance!
  2. Remove Advertisements
  3. #2
    Full throttle
    Join Date
    Jan 2002
    Posts
    16,524
    Is this a pre-2002 9-3 or a 2003-on 9-3 Sport Saloon?
  4. #3
    Hi,
    The car is a post 2003 sport saloon.
  5. #4
    Hi all,
    Glad i'm not the only one with this problem!! I have a 54 reg 93 aero and I also have stability control,abs,traction warnings just after start up,occasionally the car won't start after a journey but if left overnight will crank up ok!
    Any ideas anyone?
  6. Remove Advertisements
+ Reply to Thread
  1. Replies: 1
    Last Post: 10-24-2011, 12:47 PM
  2. Brake Light/Rear Light Failure 2006 Aero salloon
    By jeahgreg in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 09-30-2010, 12:00 PM
  3. Brake Fluid Than ABS light coming up
    By zlatkomk2000 in forum Saab 9000 (1984 - 1998)
    Last Post: 12-19-2009, 03:04 PM
  4. Brake warning light coming on
    By mikeloadsasaabs in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 02-05-2007, 04:58 AM
  5. Brake warning light keeps coming on?
    By 90t16Saero in forum Classic Saab 900 (1979 - 1993)
    Last Post: 11-14-2001, 02:22 PM
