No Reverse Light switch question...
+ Reply to Thread
Results 1 to 7 of 7
Thread: No Reverse Light switch question...
  1. #1
    I need to replace the reverse light switch on my 2000 Saab 9-5 estate 2.0t SE AUTO.
    Would GM Part No. 90482454 fit ?
    if not doe's anyone know the correct part number for the switch ?
  2. #2
    Full throttle
    Join Date
    Jan 2002
    Posts
    16,524
    The part number you quote is shown on the parts catalogue as the one for the manual gearbox. It is the current part and also the replacement for all the previous switches.
    The reverse light switch on automatic cars is incorporated into the selector lever position sensor.
    What are the symptoms that lead you to think the switch has failed?
  3. #3
    What are the symptoms that lead you to think the switch has failed?[/b]
    no reverse lights i tried fitting two new bulbs and still nothing, so i put it down to the switch
    SID doe's not display any errors...
  4. #4
    Full throttle
    Join Date
    Jan 2002
    Posts
    16,524
    It's rare on the estate, but it could be a broken wire on the way to the rear of the car. Someone recently reported finding a break in the loom, not in the hinge though, in the loom near the back of the car. One of the crimp connections was loose.
  5. #5
    Full throttle mark e's Avatar
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    From what I can see, the reversing lights on the auto are illuminated via a relay rather than DICE as is the case for manual models. As a result there's no monitoring of the circuit.
    I presume you've checked the fuse? #2 in the passenger compartment fuse board. The relay is in the main dash relay box. To check if the switch is faulty, unplug the transmission range switch connector and apply 12V to pin 7 of the free connector with the ignition on.
  6. #6
    yeah I have checked the fuse and the bulbs
    Is there a relay in the engine bay i could try renewing to see if it's at fault ?
  7. #7
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    No- see what I said above
  8. Remove Advertisements
+ Reply to Thread
  1. Reverse light switch
    By robertson.a in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 09-23-2010, 07:27 AM
  2. No reverse light, Location of reverse light switch?
    By mpett in forum Saab 9000 (1984 - 1998)
    Last Post: 06-06-2010, 12:56 PM
  3. 1992 c900 Brake light switch question
    By brian_c in forum Classic Saab 900 (1979 - 1993)
    Last Post: 10-03-2008, 02:07 PM
  4. Reverse light switch
    By 900sport in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 06-07-2008, 10:45 AM
  5. reverse light switch
    By norma1 in forum Saab 9000 (1984 - 1998)
    Last Post: 12-05-2005, 12:05 PM
