Brake and ABS light on dash, what does this mean?
NEWS
+ Reply to Thread
Results 1 to 7 of 7
Thread: Brake and ABS light on dash, what does this mean?
  1. #1
    Saab Junior
    Join Date
    Feb 2008
    Location
    Hounslow, Middlesex
    Posts
    46
    Hi I have 9-3 yr 2000. 2.0T
    Today the Brake and ABS light came on is there a common reason this happens. I.e. do the brake pads need changing or are there different reasons this could come on?
  2. Remove Advertisements
  3. #2
    Full throttle
    Join Date
    Jan 2002
    Posts
    16,524
    Could be many things.
    Did the light just flash on or is it on all the time?
  4. #3
    Saab Junior
    Join Date
    Feb 2008
    Location
    Hounslow, Middlesex
    Posts
    46
    Yes it came on this morning then didnt drive it for a few hours. Just drove it and the light went off. I have ben getting a bit of a noise when I brake every now and then dont know if this is why.
  5. #4
    Full throttle
    Join Date
    Jan 2002
    Posts
    16,524
    The ABS and speedometer take readings from the wheel sensors. If the data is disrupted you will get the warning lights.
    If you have noise, check the front sensors for contamination or a cracked tooth ring on the back of the driveshaft joint. The speedo only uses the rear sensors. So, if the speedo is OK, I would concentrate on the front end.
  6. #5
    Saab Junior
    Join Date
    Feb 2008
    Location
    Hounslow, Middlesex
    Posts
    46
    Thanks, im going to get under the car on the weekend so ill let you know how i get on. Thanks again.
  7. #6
    Saab Junior
    Join Date
    Feb 2008
    Location
    Hounslow, Middlesex
    Posts
    46
    I took off the sensors and gave them a clean but the light still comes on now and then are the sensors on the way out or could it be something else?
  8. #7
    Saab Afficionado
    Join Date
    Feb 2005
    Location
    Isle of Wight
    Posts
    1,423
    Today the Brake and ABS light came on is there a common reason this happens. I.e. do the brake pads need changing.................
    .......................... I have ben getting a bit of a noise when I brake every now and then dont know if this is why.[/b]
    It's not difficult to check whether or not the pads need changing. Noise is normally caused by insufficient material on the brake pads, rust on the edge of the disc or debris between the disc and mud guard.
  9. Remove Advertisements
+ Reply to Thread
  1. Brake Light/Rear Light Failure 2006 Aero salloon
    By jeahgreg in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 09-30-2010, 01:00 PM
  2. ABS and BRAKE light on dash
    By adamwise in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 06-21-2010, 05:44 AM
  3. ABS light, brake light, TC failure light coming on intermittently
    By rjmeer in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 11-26-2009, 07:35 AM
  4. Brake lights working but dispaly says change brake light
    By kunal247 in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 02-25-2009, 12:56 PM
  5. Replies: 2
    Last Post: 02-27-2007, 07:34 PM
