Cabin Heater Blowing Cold Air
NEWS
+ Reply to Thread
Results 1 to 7 of 7
Thread: Cabin Heater Blowing Cold Air
  1. #1
    As if it's not enough that I'm freezing my butt off in the mornings lately, my car no longer blows hot air through the vents when I turn on the heater regardless of the temperature setting. I immediately checked the coolant level and everything checks out normal, it's almost as if the cabin temperature sensor has failed and it thinks the temperature is 100 degrees! So no matter what temperature I set on the heater it tries to cool the cabin with cold air.
    Anyone got any ideas on this one?
    Thanks,
  2. Remove Advertisements
  3. #2
    Full throttle mark e's Avatar
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    Start by interrogating the ACC unit for faults. IIRC it's the same as the 9-5; press AUTO and OFF simultaneously.
  4. #3
    Thanks Mark, I've done what you recommended and it came back with the number zero displayed on the screen for about 20 seconds and then it went off. I repeated this and it came back the same. Do you have a lookup table that can identify what this code means?
  5. #4
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    Well the good news is that the zero is the number of faults found on it's self diagnostic. Sometimes just carrying out this procedure which also re-calibrates the system can cure problems. I suppose that's too much to hope for in this case...
  6. #5
    I'll find out tonight on my way home from work when I get the engine up to temperature and I'll let you know how I get on. Thanks for your help so far.
  7. #6
    Look under the hood. There are two hoses going through the firewall - one supplies the heater core with hot coolant, the other one is return. Feel if both are hot - if not, the core is blocked with debris in the cooling system.
  8. #7
    Thanks for all the replies. Resetting the ACC unit appears to have done the trick and I've got nice hot air blasting through the vents again! It's the little things in life, you know...
  9. Remove Advertisements
+ Reply to Thread
  1. Cabin Fan not Blowing?
    By aaron328 in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 11-30-2012, 09:02 AM
  2. 1999 Convertible Manual heater Blowing only cold
    By shell_n_juls in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 04-02-2010, 10:37 AM
  3. Blowing hot and cold
    By ursathedog in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 09-27-2005, 05:31 PM
  4. Ac only blowing cold
    By Saab qualified in forum Saab 9000 (1984 - 1998)
    Last Post: 09-20-2005, 12:37 PM
  5. Blowing hot and cold (ACC)
    By john in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 06-02-2003, 12:40 PM
