9000 Aero MY97 - O2 Sensor problems
NEWS
+ Reply to Thread
Results 1 to 5 of 5
Thread: 9000 Aero MY97 - O2 Sensor problems
  1. #1
    Regular Saab Guy
    Join Date
    Aug 2004
    Location
    Australia
    Posts
    89
    Hi, believe that my 9000 Aero (260,000km/161,000 miles) is exhibiting some low/moderate throttle accelration hesitation. Also had the CEL (6 flashes) indicating a O2 issue (although after parking the car and turning engoine on after approx. 4 hours the CEL light had extinguished). Car has never had the O2 sensor replaced. So I'm thinking, based on all indications, to replace the little bugger. So, what equivalent Bosch part number/O2 sensor should I be using. Exisiting O2 is a 4-wire Bosch unit. My Saab only has a single O2 sensor positioned on the downpipe close to the turbo exhaiust outlet. Also my car is running a MapTun Stage 4 with all the appropriate exhaust, iuntercooler, injector m odications. Thnx in advance. Cheers Tony
  2. Remove Advertisements
  3. #2
    Pug205GRD
    Guest
    Buy a genuine replacement part from SAAB rather than a generic one. Lots of stories about hinting that the Trionic ECU is very fussy over its Lambda sensors. Cant remember if the 4 wire is the LS25 or LSH6 version?
  4. #3
    if your running modifications it might be worth looking into a wide band type not sure if elk sell them
  5. #4
    Saab Anorak
    Join Date
    Sep 2003
    Location
    Tunbridge Wells
    Posts
    938
    Buy a genuine replacement part from SAAB rather than a generic one. Lots of stories about hinting that the Trionic ECU is very fussy over its Lambda sensors. Cant remember if the 4 wire is the LS25 or LSH6 version?[/b]
    I agree with buy a genuine one rather than generic, but only from Saab if you have feeling rich. HelpToday or Just Lambda are both much cheaper for OEM Bosch ones, although they also do generic ones for even less.
  6. #5
    Regular Saab Guy
    Join Date
    Aug 2004
    Location
    Australia
    Posts
    89
    Inspected my O2 sensor today. It is a Bosch LSH25 P/N 0258003662. The sensor showed a fine/thin coating which was mainll medium gray/black and a medium brown/tan in some patches. It was not heavily coated in soot. So no indication that engine is running rich. In fact, if enaything, the colour could verge on a leaner burn. Also checked spark plugs. Cylinders 1 thru 3 all displayed a light tan colour. This is quite normal relative to past plug replacements I have done. Cylinder 4 was noticeably darker - not black but noticeably darker in colour but still within range I believe. Again, plugs would indicate a normal combustion/burn. Anyway, I am going to replace the O2 sensor (with Bosch OE not universal - can be bothered splicing, etc) and plugs. I also believe that my AIC is also playing up - necver been replaced but has been taken out several times and cleaned with no obvious actuator problems. Anyway probably worth replacing this as well. BTW, I can purchase a Bosch direct replacement for half the price being asked by a local Saab dealership - not making any money on cars but certainly pumping the spare parts!! Cheers Tony
  7. Remove Advertisements
+ Reply to Thread
  1. 9000 Aero MY97 - 3 Bar MAP Sensor Upgrade
    By antlee in forum Saabscene: Performance
    Last Post: 08-20-2009, 05:11 AM
  2. Wierd Front Suspension Problems - 9000 Aero MY97
    By antlee in forum Saab 9000 (1984 - 1998)
    Last Post: 05-29-2007, 05:18 PM
  3. 9000 MY97 Super Aero Wheels
    Last Post: 03-23-2007, 05:30 AM
  4. MY97 9000 Aero
    By pyronerd in forum Saab 9000 (1984 - 1998)
    Last Post: 07-29-2002, 01:46 PM
  5. MY97 9000 Aero
