Saab 9-3 power loss - Engine light - Traction issues
NEWS
+ Reply to Thread
Results 1 to 4 of 4
Thread: Saab 9-3 power loss - Engine light - Traction issues
  1. #1
    Hi,
    Please can anyone offer me some advise. I have had some strange issues with my 2001 9-3 HOT. Here's the chain of events
    1. Power loss under acceleration - it will rev up to about 4k then it's almost as if the traction control has kicked in and is killing the power. The turbo gauge goes off the scale unless I ease of the accelerator immediately. The 1st couple of times this happened, the traction control switched it's self off.
    2. Even with the traction control switched off, it still behaves in the same manner
    3. The engine management light has now come on and the power loss is happening consistently.
    One thing to note - I have got a slight water leak from the thermostat housing - could this be causing any problems? It's booked in to get the leak repaired (my local dealer fitted the new thermostat a couple of weeks ago but didn't do a good job) and I will ask them to take a look at the power loss symptoms too. I just thought I would ask on here to see if anyone had experienced the same issues and knew what the possible fault could be.
    Also - has anyone got any experience of using Scanparts in Wolverhampton for servicing & diags?
    Many thanks - any advise greatly appreciated!
  2. Remove Advertisements
  3. #2
    Saab Afficionado AL900S's Avatar
    Join Date
    Apr 2003
    Location
    Manchester, UK
    Posts
    1,285
    Hi
    Have you had your direct ignition cassette replaced at all under 'recall' by Saab. (black rectangular module which sits on top of engine with a screw on all 4 corners). You can check with a Saab dealer. Run a search for DI cassette. This could well be the problem either that or a split vacuum hose near turbo/throttle body.
    HTH
    Al
    9-3 SC 1.8t Vector, metallic black/cream, paddle shift, sports wheel, premium sound, SPA & convenience pack
  4. #3
    Thanks for the advice Al.
    It turned out to be a faulty crank position sensor.
    I will check the DI cassette with the dealer - it might be that I am entitled to a nice shiny new one
  5. #4
    Join Date
    Apr 2003
    Location
    Manchester, UK
    Posts
    1,285
    Glad you got it sorted! Worth checking DI in case you have trouble down the line.
    Al
  6. Remove Advertisements
+ Reply to Thread
  1. 1999 2.2 TiD Loss of Power, EM Light, Turbo Spool.
    By David_Martin in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 01-16-2011, 06:36 PM
  2. Power loss when engine gets up to temperture
    By jcet in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 09-13-2010, 12:25 PM
  3. 9-5 Aero Traction Control and Engine Management light on!
    By saabheaven in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 07-13-2008, 09:11 AM
  4. 2.2 Tid Engine Check Light and loss of power. Help
    By moosetvr in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 11-29-2006, 10:36 AM
  5. Engine Malfunction Light & temporary loss of power
    By Mattsaab in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 04-24-2006, 06:54 PM
