9-3 dash trim removal
+ Reply to Thread
Results 1 to 6 of 6
Thread: 9-3 dash trim removal
  1. #1
    Hi there,
    I've got a 9-3, 2006 model with the aux socket in the stereo fascia; how do I remove the fascia, or take the stereo out, or even remove the trim panel below?
    A jack plug has snapped off in the aux socket
    Any advice gratefully accepted.....
  2. #2
    Saab Afficionado
    Join Date
    Dec 2007
    Location
    Stockholm, Sweden
    Posts
    1,775
    Here's a long-shot idea. Maybe, just maybe, it might be possible to superglue the two pieces together in place. Very carefully apply glue to the 'handle' of the plug (which will touch the broken off part) and hold it against the broken off piece in the socket. Try first to see how they need to be aligned for best contact. Make sure you hold it very still for as long as you can (at least a minute or two I'd say). You never know, it might just work (and save you from having to take things apart).
    Good luck.
  3. #3
    Good luck.[/b]
    Thanks for the suggestion. I did think of the glue option, but the piece left behind in the socket seems to be at a bit of an angle and I'm worried that I'll just stick the 'handle' to the dash.
    Cheers anyway......
  4. #4
    to remove the stereo, you need to carefully pry out the centre vents above the stereo. Then you will see 2 torx bolts ontop the stereo. undo these and voila. you will then have to strip the stereo down to gain access to the aux port, whcih may not be so easy.
  5. #5
    Thanks, Steve................
  6. #6
    Can anyone tell me how to remove the dash trim itself? I have a 2004 93 convertible and the trim or "bezel" is pealing. Picked up a new one but can't get the old one off!
  7. Remove Advertisements
+ Reply to Thread
  1. 2004 Dash Bezel/trim removal
    By Dredlocd in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 04-06-2011, 06:26 PM
  2. Help With Removing Dash Trim
    By vipercon in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 01-07-2009, 04:20 PM
  3. Wood dash trim
    By rainbird in forum Saab 9000 (1984 - 1998)
    Last Post: 05-13-2008, 02:50 AM
