ACC Temperature Control Problem
NEWS
+ Reply to Thread
Results 1 to 3 of 3
Thread: ACC Temperature Control Problem
  1. #1
    Motor Mouth
    Join Date
    Nov 2002
    Location
    Marlow, Buckinghamshire, UK
    Posts
    2,928
    On a long journey the cabin temperature will drop after an hour or so, so I increase the set temp by 1C. After another hour or so it will drop again, and so on. I often end up with 25C set temp instead of 22C. When this happened a couple of years ago, I bought a new cabin temp sensor and things improved for a while. Last week in a journey of about 350 miles, I ended up with the temp set to HI occasionally to get some heat out. Switching the ACC off for a few minutes improved things.
    So the questions:
    1) Is it likely to be the cabin temp sensor again? Do other people's only last 3 years or so?
    2) Could it be something else, like the sun sensor over reacting with time?
    3) Is it possible to replace the electronic widget in the cabin sensor as a new sensor is not cheap?
    Thanks as always.
  2. Remove Advertisements
  3. #2
    Motor Mouth
    Join Date
    Oct 2002
    Location
    Kippen, Stirling
    Posts
    2,038
    Mark,
    It's always worth picking the accumulated fluff off the sensor element. Just use tweezers to pull out the grille then carefully pick off the fluff. It tends to have an insulating effect on the element.
    Paul @ Kippen.
  4. #3
    Motor Mouth
    Join Date
    Nov 2002
    Location
    Posts
    2,928
    I did that when I got to the end of my journey, and strangely enough the return journey wasn't as bad, either 2 or 3 degees up after over 500 miles. I've found my old unit and an now hunting for a suitable replacement thermistor to make a usable spare.
  5. Remove Advertisements
+ Reply to Thread
  1. Temperature gauge problem
    By Smoggy in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 04-03-2008, 11:54 AM
  2. Outside Temperature Problem
    By cobra7512 in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 11-01-2005, 01:27 PM
  3. a/c system / temperature control
    By swiltshire in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 07-12-2004, 04:27 PM
  4. Climate Control Temperature Sensor & Wiring Diagram
    By Ian R in forum Saab 9000 (1984 - 1998)
    Last Post: 09-02-2001, 08:19 PM
  5. Climate Control Temperature Sensor & Wiring Diagram
