I have a problem with the soft top on my 2001 9-3, when the top is fully up the window on the passenger side catches the roof, and does not sit in the rubber seal, this causes excessive wind noise at speed and also causes the electric window to jam. I have looked in the Haynes manual, but there is no mention on how to adjust the roof.
I have looked at both sides of the roof and on the faulty side the 1st bar is slightly apart where it hinges (Causing the roof to dip very slightly); if this can be adjusted I think it will sort the problem out. I don’t fancy going to the Saab dealer and handing over my life savings and the shirt off my back for a simple solution. Any advice would be greatly accepted
