fuel pump fuse
NEWS
+ Reply to Thread
Results 1 to 5 of 5
Thread: fuel pump fuse
  1. #1
    Saab Newbie
    Join Date
    Nov 2005
    Location
    shropshire England
    Posts
    15
    Hi my 20 amp fuel pump fuse keeps blowing in the space of 10 miles my fuel pump fuse has blown 4 times so to get home i put a 30 amp fuse in which for the 10 miles home it didn't blow first will this action cause any damage and secondly is my fuel pump had it or could it be something simple and cheap to do like needing a new fuel filter or something please advise
  2. Remove Advertisements
  3. #2
    Saab Afficionado
    Join Date
    Feb 2005
    Location
    Isle of Wight
    Posts
    1,423
    Sounds like it could be the pump on the way out, but worth checking cheaper options first. There is a relay for the pump (at least there is on mine ) and if that is not making good contact, it could cause overheating in the fuse. Not sure if there is another relay on the same board, which you could swap it with to find out. Probably not a good idea to up rate the fuse, as the fuel tank is not the best place to have something go into meltdown!ps Is the alternator good and keeping the battery fully charged etc? With all the extras on, there could be a drop in voltage. Less volts mean more amps. Power = volts x amps. Might be OK in the morning, if it is not pouring of rain and the lights are off
  4. #3
    Saab Newbie
    Join Date
    Nov 2005
    Location
    shropshire England
    Posts
    15
    Changed fuel pump and everything is ok now it cost me 52 for a second hand one
  5. #4
    Saab Afficionado
    Join Date
    Sep 2004
    Location
    Stevenage
    Posts
    1,094
    Changed fuel pump and everything is ok now it cost me 52 for a second hand one[/b]
    Thanks for letting us know. I am sure quite a few of us were worried about you running around with an overrated fuse in the fuel system.......
    Neil
  6. #5
    Saab Junior
    Join Date
    Oct 2006
    Location
    Cardiff
    Posts
    38
    Can you please tell me from where you bought the fuel pump. my car wont start and I think the problem is fuel pump.
    cheers
  7. Remove Advertisements
+ Reply to Thread
  1. 2004 9-3 fuel pump fuse location?
    By Gizo in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 08-20-2009, 04:34 PM
  2. No start, no fuel pump fuse power
    By reidboat in forum Saab 9000 (1984 - 1998)
    Last Post: 03-10-2009, 04:31 PM
  3. Fuse #5 keeps blowing, never hits fuel cutoff in tests
    By rezzen in forum Saab 9000 (1984 - 1998)
    Last Post: 12-15-2008, 01:37 AM
  4. Fuel pump versus feed pump?
    By andysapora in forum Saab 9000 (1984 - 1998)
    Last Post: 12-12-2006, 11:46 AM
  5. fuel pump
    By gelcoat in forum Saab 9000 (1984 - 1998)
    Last Post: 05-29-2004, 09:41 AM
