Rear Brake Caliper not retracting
NEWS
+ Reply to Thread
Results 1 to 11 of 11
Thread: Rear Brake Caliper not retracting
  1. #1
    Saab Nut BertieBentnose's Avatar
    Join Date
    Jan 2007
    Location
    Allendale, Hexham
    Posts
    414
    Title says it all mainly!
    I have decided to be brave and change the rear discs and pads rather than pay the mechanic and all was going OK until I came to replace the old pads with new on the 2nd side.
    I have turned the 4mm allen screw as far as it will go to retract the caliper piston but it has not retracted fully. I am concerned that continuing with force to turn the 4mm allen screw could do more damage.
    Is this the right way to continue (with force) or is there some other fix?
    I am following the instructions at www.saab9000.com which seem to be very accurate (even the colour of the car matches!)
    Any help gratefully received.
    Bertie
  2. Remove Advertisements
  3. #2
    Full throttle mark e's Avatar
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    Sounds like it's corroded/worn. You could try applying some compression to the caliper with water pump pliers whilst turning the screw but realistically (and safely) you're looking at a new caliper.
  4. #3
    Join Date
    Jan 2007
    Location
    Allendale, Hexham
    Posts
    414
    Thanks for that Bubbles,
    I guess I'll be on the lookout for a new caliper then.
    Bertie
  5. #4
    Join Date
    Jan 2007
    Location
    Allendale, Hexham
    Posts
    414
    Just a quick question about calipers.
    Does anyone happen to know if a caliper from a pre 94 9k would fit on a post 94 9k (and work!)
    Saab have quoted £116 + Vat for a new one (p/n 7895337) and I am trying to avoid paying that much!
    Bertie
  6. #5
    Saabisti
    Join Date
    Oct 2006
    Location
    Oxford, UK
    Posts
    159
    Bertie[/b]
    You could try GSF Car Parts (www.gsfcarparts.com). Their rear calipers are about half that. They're not in a Saab box, but are probably made in the same factory
  7. #6
    Saab Fan
    Join Date
    Apr 2007
    Location
    Northampton
    Posts
    53
    Have you tried ;
    German and swedish ?
    Always good prices for me (£65 for a rear hub bearing combo, SAAB wanted £120 plus Vat, bless them)
  8. #7
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    GSF are German and Swedish (the F is French).
    Any 9000 rear caliper will fit, as will any MY88 onwards C900.
  9. #8
    Join Date
    Jan 2007
    Location
    Allendale, Hexham
    Posts
    414
    Thanks for those replies.
    GSF is £59 (much cheaper) plus £30 surcharge refundable when I send them the old one. Is this common practice?
    Bertie
    PS - I'm confused. My duff one is the drivers UK (off side). Is this the left or right and left or right as from looking at the front of the car or looking the way is normally travels? I don't want to get the wrong one!
    PPS - Thanks Bubbles
  10. #9
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    Yes, surcharge is normal. Your old housing is refurbished. Indeed the caliper you buy will be likely as not a refurbished unit. The Saab price does not allow for refurbishing, and is brand new, hence the differential.
    Offside in the UK is right hand.
  11. #10
    Turbo Talker trollbooster's Avatar
    Join Date
    Feb 2005
    Location
    Whitley Bay, Northumberland
    Posts
    4,626
    £58 from Brakeparts.co.uk , so everyone is in the same ballpark.
  12. #11
    Join Date
    Jan 2007
    Location
    Allendale, Hexham
    Posts
    414
    So my new caliper arrived today from GSF. It looks very shiney and not at all what I expected a re-con one to look like.
    I will get the new caliper put on the car probably tomorrow and then I hope that all future posts (for a while at least) will be offering advice rather than requesting it because another bit has stopped working.
    I think that most of the major components have now been replaced so, touchwood, a few years of 'nothing major to report' is expected.
    Thanks again to all for help and advice since July 16 when the gearbox went bang!
  13. Remove Advertisements
+ Reply to Thread
  1. rear brake caliper rebuild kit
    By saabanni in forum Saab 9000 (1984 - 1998)
    Last Post: 08-10-2008, 09:43 AM
  2. Rear ATE Brake Caliper Rebuild
    By Murphys001 in forum Classic Saab 900 (1979 - 1993)
    Last Post: 01-25-2008, 02:07 PM
  3. Rear Brake caliper adjusting screw
    By Grayedout in forum Classic Saab 900 (1979 - 1993)
    Last Post: 03-15-2006, 05:20 AM
  4. Need rear brake caliper
    By Liam in forum Saab 9000 (1984 - 1998)
    Last Post: 12-06-2001, 04:30 PM
  5. Need rear brake caliper
