Saab 9000 CSE Turbo 1993 wont start HELP
NEWS
+ Reply to Thread
Results 1 to 4 of 4
Thread: Saab 9000 CSE Turbo 1993 wont start HELP
  1. #1
    Hi, this is my first post in the forum, I am new to Saab cars, always love the look of these cars, I got this car (9000 Turbo CSE 1993 auto) from a friend who have the car parked for a long time, I put a new battery and gas, try to start the car but it wont start ( it cranks but no start), I check the main relay (ok) pump relay (ok), I check and have no power to the inyectors, I even try to put a cable direct from the battery to the inyectors cable but have no pulse. My question is is there any fuse that I am missing?? and I think one possible cause of this, is that a rat or a mouse brake a cable that goes to the inyectors since the car have been park outside in a farm for a long time. Any advise would be great. Thanks in advance
  2. Remove Advertisements
  3. #2
    Motor Mouth
    Join Date
    Oct 2002
    Location
    Kippen, Stirling
    Posts
    2,038
    acha3,
    Being a 1993 car, I'm not sure whether it has a traditional style distributor, or the later, Direct Ignition ( DI ) module. If it has a distributor then the first place to look is inside the cap. Is it all clean, does the rotor arm look OK. Does the sprung carbon contact in the centre move in and out when you press it. Clean up the plug leads and the centre one to the coil. Take a plug out and check for sparks.
    If you have the DI pack ( big red unit on the top of the cam cover held down by 4 bolts ) then it could be that this has failed. It is possible to test them but you need to be careful since it generates life threatening voltages when in action.
    Can you hear the fuel pump running when you turn on the ignition. You could check for voltage at the pump, under the rear seat. The other item that may be faulty could be the crank position sensor. Does the rev counter needle flick slightly when cranking. If not then it probably isn't working. There are two positions for these depending on the year. I think later engines have them down the back below the starter motor.
    Paul @ Kippen.
  4. #3
    Full throttle mark e's Avatar
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    Welcome to Saabscene .
    Your car will definitely have a DI cartridge, which is one possible cause. The other is a faulty crankshaft position sensor. Does the tacho (rev counter) needle flicker whislt you are tryign to start the car?
  5. #4
    Thanks for the information, i will check this tomorrow and let you know.
  6. Remove Advertisements
+ Reply to Thread
  1. 1992 Turbo wont start
    By rossbielski in forum Saab 9000 (1984 - 1998)
    Last Post: 05-09-2011, 11:26 AM
  2. 1993 Saab 9000 CSE Turbo, parting out
    By 939000cse in forum Saab Parts / Accessories, FOR SALE and WANTED
    Last Post: 07-26-2010, 07:48 AM
  3. saab 9000 1993 2.3 turbo breaking
    By whettonmark@aol in forum Saab Parts / Accessories, FOR SALE and WANTED
    Last Post: 08-26-2008, 03:22 PM
  4. My 86 9K turbo wont start
    By KASANOVA in forum Saab 9000 (1984 - 1998)
    Last Post: 06-15-2008, 01:28 PM
  5. Saab 9000 CSE 2.0 non turbo 1993
    By Dan@DB-Power in forum Previous model ranges, FOR SALE and WANTED
    Last Post: 11-28-2007, 12:18 PM
