Hazard Switch has fallen into dashboard.
NEWS
+ Reply to Thread
Results 1 to 6 of 6
Thread: Hazard Switch has fallen into dashboard.
  1. #1
    I have a 1997 Saab 9000 Turbo. The other day I needed to use my hazard lights so I pressed the hazard switch on the dash board and the entire switch fell into the dash board. I noticed that one other person has posted this problem but no one ever responded. What's the best way to fix this? Will I have to take out the entire dash board or should I try fish out the hazard switch. Does anyone know if this is a common problem?
    Thanks for any advice.
  2. Remove Advertisements
  3. #2
    Turbo Talker trollbooster's Avatar
    Join Date
    Feb 2005
    Location
    Whitley Bay, Northumberland
    Posts
    4,626
    I think it is quite a common problem, the retaining lip on the switch is way too thin - considering that most people quickly jab the switch in a hurry (cos there's a hazard). To fish it out try taking the clock or the heater control panel out.
  4. #3
    Motor Mouth
    Join Date
    Oct 2002
    Location
    Kippen, Stirling
    Posts
    2,038
    Ranv,
    My friendly local garaged managed to do this for me when I put it in for an MOT a couple of years ago ( Break it, not fix it !) I managed to fish it out with a piece of stiff wire the first time. Tried to reglue the trim ring back on but that only lasted a couple of uses. Next time I just took off the dash top to retrieve it. Not too difficult, just don't loose the 5mm washer from the right hand side bolt that is under the speaker grille.
    Paul @ Kippen.
  5. #4
    Saabisti redrocket's Avatar
    Join Date
    Mar 2003
    Location
    Hampshire UK
    Posts
    200
    i find the easiest way to get to the hazard switch is to take the clock unit out
  6. #5
    Saab Fan
    Join Date
    Apr 2006
    Location
    upstate NY, USA
    Posts
    73
    easy, take out the ashtray, reach in and up and pop the ACC out.
    then pop out the clock if you like, or just work thru the big ACC hole.
  7. #6
    Hey, thanks for all the responses. I did mostly what you guys suggested. I took out the Air Conditioning and Heating Panel (it pops out easily) and then I found the hazard switch. It turns out that the switch had broken so thats why it fell into the dash. I guess I'll have to replace it. Thanks again for the responses.
  8. Remove Advertisements
+ Reply to Thread
  1. Hazard switch damaged
    By cliffhanger in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 01-12-2010, 06:41 AM
  2. Warning Lights ABS,TCS,Brake,Hazard on dashboard
    By gerwill in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 01-16-2008, 04:26 AM
  3. Hazard light switch
    By hob_the_builder in forum Saab 9000 (1984 - 1998)
    Last Post: 08-08-2007, 10:51 PM
  4. Hazard warning switch
    By swintonian in forum Saab 9000 (1984 - 1998)
    Last Post: 10-06-2004, 04:42 PM
  5. Hazard warning switch
