95 SAT NAV DVD required
NEWS
+ Reply to Thread
Results 1 to 2 of 2
Thread: 95 SAT NAV DVD required
  1. #1
    Hi, has anyone got a copy (copy or original) of the SAT NAV disc for the 95 for sale? A friend of mine has a 95 2.2 Vector tith the touch screen system with a worn out 1995 disc. The later the better but any 95 disc would do as the disc is completely worn and will not read at all. Were not sure if it is the disc or the player but if we try a replacement disc then we will know for sure where the problem lies.
    Thanks,
    TL
  2. Remove Advertisements
  3. #2
    ...if you have difficulty, you can try using 't-cut' and vigorous polishing... it will slowly cut the edges of the scratches back until the laser is able to read the DVD tracks once again. Patience is required!
    (If the reflective gold or aluminium layer under the label side has been scratched through, this method will not work; this fails also if the scratches are deep enough to cut into the dye layer of a writeable DVD which is protected only by a thin varnish).
  4. Remove Advertisements
+ Reply to Thread
  1. More RAM required
    By Swade in forum Saab News
    Last Post: 01-19-2007, 10:08 AM
  2. Help Required
    By mikey in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 05-04-2004, 01:27 PM
  3. Help required
    By saabman in forum Help, Advice, Saabs and Motoring
    Last Post: 01-06-2003, 08:31 AM
  4. 99T rad fan required
    By john in forum Saab 99, 90 (1969 - 1984)
    Last Post: 05-20-2002, 01:48 PM
