Auto gear shift lever illuminator bulb replacement
NEWS
+ Reply to Thread
Results 1 to 8 of 8
Thread: Auto gear shift lever illuminator bulb replacement
  1. #1
    Saab Afficionado
    Join Date
    Jan 2004
    Location
    England
    Posts
    1,813
    I tried doing a search on the forum but for some reason I could not find anything - maybe as I was doing it wrong?
    I need to replace the bulb that illuminates the P D R M 1 2 lights (or whatever order they are in) along side the auto gear lever - is it simple or is it a pig? I do not want to go prising off anything unnecessarily.
    Any tips or links to any other posts would be much appreciated!
    Thanks!
  2. Remove Advertisements
  3. #2
    Saab Nut
    Join Date
    Apr 2004
    Location
    london
    Posts
    480
    Re: Auto gear shift lever illuminator bulb replacement
    This is for the 4 speed box but i suspect the 5 speed is similar.
    Carefully prise up the gearlever surround, remove the gearlever position indicator panel followed by the green strip and slider, remove the graded strip then use a suitable piece of rubber tube to remove the faulty bulb.
  4. #3
    Saab Nut speers's Avatar
    Join Date
    Nov 2003
    Location
    Kent, UK
    Posts
    317
    Good Grief, there is a light?
    I was assuming that the reason there was the display on the dash that there was not a light behind these! Mine is the 6 speed I think, PRND32L I think the order is.
    I shall have a look at removing this panel and changing the bulb!!
  5. #4
    Saab Afficionado
    Join Date
    Jan 2004
    Location
    England
    Posts
    1,813
    I am either going mad - or there was a bulb - as I got in the car and went to change gear yesterday - and could not see it! I am sure I always look there to change gear - I never look at the dash - though very handy that it is!
    Thanks for your help! I did not want to go ripping it all out to find that you can do it another way !!
  6. #5
    Saab Anorak
    Join Date
    Aug 2005
    Location
    Cambridge
    Posts
    539
    I don't think mine has a light down by the stick: nor does it have a 'winter' button - just the space where it was in earlier versions. It has lights on the instrument panel to tell you what is going on.
    Perhaps arrival of flappy paddles on the 5 speed auto, winter button deleted at the same time, also co-incided with the deletion of illumination by the stick?
  7. #6
    Saab Anorak
    Join Date
    Aug 2005
    Location
    Cambridge
    Posts
    539
    Stupidity retracted
    Just been out to collect 10 year old from football - mud, mud and mud. Anyway - it does light up down by the stick but only when lights are on - its not with the ignition. Shows how often I peer down beyond my left knee.
  8. #7
    Full throttle
    Join Date
    Jan 2002
    Posts
    16,524
    The Winter button just started the car in third gear.
    The flappy paddles allow you to select 1 2 or 3 from standstill.
  9. #8
    Saab Afficionado
    Join Date
    Jan 2004
    Location
    England
    Posts
    1,813
    Yes the winter button (RIP) does look pretty though!! Until you try and buy a new one!! I think it was 70 in my 900 about 8 years ago !!
  10. Remove Advertisements
+ Reply to Thread
  1. sticky gear lever
    By lorien6666 in forum Help, Advice, Saabs and Motoring
    Last Post: 08-21-2010, 02:57 PM
  2. Auto Transmission Lever Bulb Not Working
    By neoseal in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 03-02-2010, 06:26 PM
  3. Removal of auto gear lever
    By robjgc1969 in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 02-21-2009, 12:59 PM
  4. Replacing Auto Gear Selector Bulb
    By ferrisio in forum Saab 9000 (1984 - 1998)
    Last Post: 08-01-2004, 10:47 AM
  5. Replacing Auto Gear Selector Bulb
