Brake lights stay on.
NEWS
+ Reply to Thread
Results 1 to 5 of 5
Thread: Brake lights stay on.
  1. #1
    Saab Newbie
    Join Date
    Oct 2006
    Location
    Rocky Mount NC
    Posts
    21
    Brake lights stay on. I have a 97 Saab 9000 and the brake lights stay on no matter if I press on the brakes. Help.
  2. Remove Advertisements
  3. #2
    Saab Anorak
    Join Date
    Jul 2003
    Location
    Middlesex
    Posts
    968
    Re: Brake lights stay on.
    Is this a Full Preasure Turbo? If so do you get just base boost (boost guage needle stayes in the middle of the orage section). If so could possible be a brake peadle switch??
  4. #3
    Saab Afficionado aeroadster's Avatar
    Join Date
    Sep 2004
    Location
    Barnet, North London
    Posts
    1,063
    Have you changed the bulbs or checked the bulb connectors for oxidation.
    I've experienced both of these in the past.
    If it's not the bulb at fault, take a bit of fine sandpaper to the connectors.
  5. #4
    Turbo Talker Trollbooster's Avatar
    Join Date
    Feb 2005
    Location
    Whitley Bay, Northumberland
    Posts
    4,626
    Try hookin your toe under the pedal and lifting it. If that works, the switch is out of adjustment. I would have thought it the contacts were corroded the lights wouldn't work at all, rather than be stuck on?
  6. #5
    Join Date
    Oct 2002
    Location
    Kippen, Stirling
    Posts
    2,565
    Thatracer,
    Re-reading your original post, I suspect that we may have taken a wrong track. Do you mean that the lights on the rear of the vehicle stay on all the time or just that the lights on the mimic diagram on the dash display stay on ?
    If it's the former then the guys have got it correct, switch adjustment or pedal return spring. If not then it indicates that a brake light bulb ( rear of vehicle ) has blown or is close to doing so. I tend to always replace bulbs in pairs 'cause the mimic can be a bit oversensitive. Keep the OK one as a spare in the tool kit for future use.
    Paul @ Kippen.
  7. Remove Advertisements
+ Reply to Thread
  1. Brake lights working but dispaly says change brake light
    By kunal247 in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 02-25-2009, 12:56 PM
  2. 99 9-5 rear brake lights stay on
    By Terunce in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 01-10-2008, 02:13 PM
  3. All lights come on when I brake
    By culham in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 08-31-2007, 09:49 PM
  4. Led Indicator, Rear Lights & Brake Lights
    By Johnboy in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 01-18-2007, 06:42 AM
  5. brake lights
    By sbeattie1975 in forum Saab 9000 (1984 - 1998)
    Last Post: 07-28-2003, 05:35 AM
