Running Temperature
NEWS
+ Reply to Thread
Results 1 to 4 of 4
Thread: Running Temperature
  1. #1
    Running Temperature
    i have just bought a 1993 Saab 9000 CS and I'm concerned about how hot it gets. When driving in traffic it goes from 1/2 to 3/4 temp all the time and the when I get it there is a general smell of hot engine.
    I spoke to the garage that sold it to me and they said it was normal for Saabs to fluctuate in temparature up to 3/4 to improve efficiency in burning fuel. I find this a bit hard to believe.
    Is this normal behaviour for a Saab or is there a problem?
    Thanks, Nick.
  2. Remove Advertisements
  3. #2
    Full throttle mark e's Avatar
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    Re: Running Temperature
    Welcome to Saabscene.
    Your garage is correct. Early 9000s have a particularly sensitive temperature gauge, which accurately reflects the real world variation in temperatures.
    In later models, owing to the alarm this caused in customers, they changed the dash temperature gauge from direct reading to being controlled by the ECU, meaning that the needle would sit in a "normal" position over a much wider range of temperatures.
    However for peace of mind, you could always use a coolant flush to clear any accumulated debris out of the system and improve efficiency. The two-part flushes are the most effective.
  4. #3
    Saab Junior
    Join Date
    Feb 2006
    Location
    Ngaruawahia, New Zealand
    Posts
    43
    You could try running the car cooler. Might be a good idea for an Australian summer.
    Install an 82ºc thermostat. And a lower temp radiator fan switch.
    Make sure the thermostat is OE SAAB part# 8817538.
    The fan switch is a Wahler part#s 321959481D85 (I think this is the VW part#) or 321959481
    A decent flush can make quite a difference. Mercedes coolant is recommended.
    The townsend site has a write up on cooling system issues.
    http://townsendimports.com/Web/cooling_sys...system_docs.htm
  5. #4
    Saab Nut Doive's Avatar
    Join Date
    May 2006
    Location
    Hexham, Northumberland
    Posts
    480
    Yep, that's a standard feature. I thought mine was broken too, every other car I've owned would only get to 3/4 on the gauge on a really hot day when sitting in traffic, whereas the Saab seems to do it regularly when stationary. I've checked the coolant system and all seems well. I find it most strange to be able to watch the thermostat open.
  6. Remove Advertisements
+ Reply to Thread
  1. Outside Temperature
    By tessman in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 11-09-2010, 07:34 PM
  2. Temperature gauge showing cool running
    By mikeloadsasaabs in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 02-03-2009, 01:53 PM
  3. Outside Temperature
    By langoir in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 05-26-2008, 12:00 PM
  4. TEMPERATURE
    By paxter_grant in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 11-12-2007, 11:37 AM
  5. Temperature on SID
    By Grossy in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 11-11-2006, 05:52 AM
