Strange clunking noise from front end
+ Reply to Thread
Results 1 to 15 of 15
Thread: Strange clunking noise from front end
  1. #1
    Saab Nut
    Join Date
    Jan 2002
    Location
    Nr Exeter, Devon, UK
    Posts
    403
    This has been an ongoing issue for some time now, but as I had planned to replace every thing at the front end (suspension wise) I thought it would go away.
    What I am getting is a staged clunking noise i.e it goes CLUNK clunk
    This will happen when coming to a halt and pulling off (not all the time tho) it doesn't seem to matter if it's on full half or no lock
    It only seems to come from the passenger side front.
    Car has in the last 2 months had all engine mounts replaced (saab oe ones) and I have polly bushed (both sides) top engine stabiliser, polly gearbox mounts, polly steering rack bushes , new sas front & rear ARB , Koni shocks (been on for a few years now).
    I have checked and tightened every nut,bolt and screw on the front of the car and can find no movement any where.
    This is becoming a every weekend challenge to find the culprit, which is a real PITA as I only drive the car on the weekends
    Has anyone got an idea of what could be causing it and or any of the polly bits fitted that might be the issue, I would really appreciate your ideas.
    Damo
  2. #2
    Saab Fan
    Join Date
    Dec 2003
    Location
    Switzerland
    Posts
    50
    Re: Strange clunking noise from front end
    Had the same thing happen to my 9K.
    The strange thing is that it only happened when the car was warm.
    Since I couldn't find out where it could come from, I just jacked up the car and torqued down every nut and bolt I could find.
    After that It was gone.
    Unfortunately the way I solved the problem, I can't say exactly what it was.
    (there were quite a couple of bolts not properly torqued down!)
  3. #3
    Saabisti
    Join Date
    Jun 2003
    Location
    Manchester
    Posts
    222
    Could be the CV joint if it is worn.
  4. #4
    Saab Nut
    Join Date
    Jan 2002
    Location
    Posts
    403
    Checked the cv joints and no probs there, although there is a lot of slack in the diff (which I was going to post about soon as well !!)
    Damo
  5. #5
    Join Date
    Oct 2002
    Location
    Kippen, Stirling
    Posts
    2,546
    Damob,
    Long, long time ago in a far and distan....... No, not that one.
    I once had a similar CLONK on stopping, reversing up and sometimes on moving off. It was on a 1979 Hillman Hunter GT. After a couple of fruitless visits to the garage I took the wheels of and started poking about ( Dad's new car, me only 17 !) Transpired it was the pad material coming loose from the backing plate allowing a slight movement. Worth a look. Whip the pads out and check they are as they should be.
    ...........d they all lived happily ever after.
    Paul @ Kippen.
  6. #6
    Saab Nut
    Join Date
    Jan 2002
    Location
    Posts
    403
    Ill give that a go Paul, not thought of that one but could be as the car was sat for a long time and moisture could of got in.
    Cheers nice one - like the story too.
    Damo
  7. #7
    Saab Fan
    Join Date
    Apr 2006
    Location
    upstate NY, USA
    Posts
    73
    i have heard similar noises from the brake pads too, sometimes they are a loose fit in the caliper slider areas
    make sure the calipers are tight to the knuckle
    on 9000s sometimes the subframe will loosen itself, causing all sorts of mayhem when trying to accelerate, decelerate, or change direction. check the bolts and retighten
    other than that it could be the usual balljoint or tierod.
  8. #8
    Saab Anorak
    Join Date
    Mar 2006
    Location
    Edinburgh
    Posts
    546
    My aero had developed a "clonking" recently, so I'd been folowing this thread with interest.
    It seemed to be coming from the passenger side and only when making turns. I assumed the worst - track rod ends, ball joints etc & got Jim to cast his expert eye over things, but he couldn't see anything wrong
    Well I solved the problem this morning, by removing the large wheel nut socket that had been rattling around inside the centre cubby hole and clunking when going round corners
    Wish all my problems were that easy / cheap to fix
  9. #9
    [ QUOTE ]
    [/ QUOTE ]
    Including the driveshaft nuts?
    www.saab9000.com - all you ever wanted to know about the Saab 9000
    www.saabits.com - stuff to help keep Saabs on the road
    Classic Saab 900 E-Code Headlamps
  10. #10
    Saab Nut
    Join Date
    Jan 2002
    Location
    Posts
    403
    Thanks again guys for your input.
    To answer all: yep checked driveshaft nuts (my torque wrench only just goes up to the correct footage) but there was no movement at all with that and a big bar.
    Already tightened the subframe joint bolts (had that issue with my 2L 9k) so knew about that one
    But I will check the brake pad idea this weekend, I doubt it's that pads moving in the calliper as they ds2500 and a tight fit IIRC, but the possibility that the friction pad might have come away from the backing is well worth checking out.
    speedypancake I wish mine was that easy to solve
    BillJ what do you know about getting the diff serviced/refurbed as there is an awful lot of slack in it.
    I'm a bit annoyed cos the gearbox was removed by a local gearbox centre as they thought it had died and told me that they would fully recon it, but when I picked the car up they told me it wasn't the gearbox after all.
    But they still took it apart and charged me £500 for the privilege
    Cheers again
    Damo
  11. #11
    Saab Afficionado
    Join Date
    Sep 2002
    Location
    Dorset, UK
    Posts
    1,749
    This is a pretty useful list of possible problems:
    http://townsendimports.com/Web/suspension_...umnandnoise.htm
  12. #12
    [ QUOTE ]
    [/ QUOTE ]
    Have you got something to compare it to? I have always found a fair amount of backlash in the diff in a 9000. I think it's normal. The diff itself doesn't seem to be a weak point. The final drive gears have been known to strip but I don't think this gives excessive backlash (until it's failed completely, of course )
  13. #13
    Saab Nut
    Join Date
    Jan 2002
    Location
    Posts
    403
    [ QUOTE ]
    [/ QUOTE ]
    No I haven't not a saab anyway, but compared to the front diff on my friends FWD MG rally car (no special diff) and a 4WD cossie front dif there does seem to quite a considerable difference, Plus a couple of my motorsport mechanic friends took a look and said it was pretty slack.
    As far as I am aware when the gearbox centre "ripped me off " they said that the box was in good condition.
    Thus I was wandering if it is viable to just get the diff recond, I know that setting the backlash is a bit of a sod unless you know what your are doing so I was hoping there might be someone out there who knows a man that can
    Damo
    Oh and thanks JohnCC for the link, have read all and still no more new ideas
  14. #14
    Turbo Talker
    Join Date
    Feb 2002
    Location
    linlithgow
    Posts
    4,215
    my strange clonking was finally tracked down to the hub itself
    the bit that holds the ball joint in place had excessive play
    so new hub carrier later ......
  15. #15
    Saab Nut
    Join Date
    Jan 2002
    Location
    Posts
    403
    [ QUOTE ]
    ylee coyote: my strange clonking was finally tracked down to the hub itself
    [/ QUOTE ]
    Yeah did check these and I did replace the lower mounts that attach to the hub (can't think of the proper name - been on late emergency server call -and brain just wants to shut down now )
    Ta again
    Damo
  16. Remove Advertisements
+ Reply to Thread
  1. Strange noise from front off side
    By Darren4963 in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 06-29-2011, 06:34 PM
  2. strange front end noise
    By pinholeburn in forum Saab 9000 (1984 - 1998)
    Last Post: 05-20-2005, 02:05 PM
  3. strange front end noise
  4. clunking noise from front right corner
    By irisw108 in forum Saab 9000 (1984 - 1998)
    Last Post: 06-30-2004, 09:31 AM
  5. clunking noise from front right corner
