9-3 M02 lowering springs
NEWS
+ Reply to Thread
Results 1 to 8 of 8
Thread: 9-3 M02 lowering springs
  1. #1
    Saab Newbie
    Join Date
    May 2006
    Location
    Italy
    Posts
    6
    Hi there,
    anyone experienced with ? In particolar, I'm looking for comments on Kilen, Eibach and Abbott spring kit. TIA
    Best.
  2. Remove Advertisements
  3. #2
    Saabisti
    Join Date
    Jan 2004
    Location
    Ireland
    Posts
    185
    Re: 9-3 M02 lowering springs
    I put Abbott springs and konis on my 93 M00 LPT very happy with same
    They are a litter harsh but not overly so and they lower the car only 25 mm so I hvae had no problems with ramps etc.
    Also put VRK, up rated Rear ARB and steering rack clamp which tightened up everything nicely
    Regards
    Eoin
  4. #3
    I installed the eiback pro spring and damper set and very pleased. It wasnt to harsh but much better than aero standard suspension
  5. #4
    Saab Nut
    Join Date
    Oct 2001
    Location
    Aberdeen
    Posts
    477
    I have Eibach Springs with Koni Dampers on my Aero, and I had Abbott Springs with Koni Dampers on my previous 900. I'd say that the Eibach springs give a more comfortable day to day ride, but no difference between them when you're pushing them through the twisty bits
  6. #5
    Turbo Talker
    Join Date
    Jan 2003
    Location
    North Yorkshire
    Posts
    4,427
    Hirsch springs & dampers on mine, excellent. Happen to be made by Eibach too...
  7. #6
    Saabisti GerrardSpear's Avatar
    Join Date
    May 2006
    Location
    Hampshire (just)
    Posts
    246
    Did exactly the same as Eoin, great result. Car feels really sorted and corners flat and true.
  8. #7
    Yes, me too, ditto Eoin and Converted, everything as per the Abbott site except the front subframe brace as I didn't want to lose clearance. Great result and a better ride in mine than with the standard set-up on most surfaces. The poly bushes and rack clamp haven't increased noise or vibration and torque steer has gone
    Dick
  9. #8
    Saabisti
    Join Date
    Jan 2004
    Location
    Ireland
    Posts
    185
    Funny about that sub frame brace.
    I talked it over at the time with my dealer and he said the brace does not reduce ground clearance
    i.e. its no lower then the sump.
    Where it does effect you is if you park head on to a high kerb then it will reduce clearance as it is fitted proud of the front tires.
    I all ways reverse into a space so doesn't affect me so got it put on.
    Went for MOT / NCT here and they measure the percentage difference in the suspension before upgrades 12% front and 14% rear differential: after 0% front and 4% rear.
    Wonder if the 0% is due to the brace
    Regards
    Eoin
  10. Remove Advertisements
+ Reply to Thread
  1. Lowering Springs
    By nicruiser in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 03-06-2009, 12:26 PM
  2. lowering springs
    By JayT1788 in forum Saabscene: Performance
    Last Post: 04-10-2007, 08:21 AM
  3. T8 Lowering springs
    By Bussman in forum Classic Saab 900 (1979 - 1993)
    Last Post: 10-06-2005, 03:10 AM
  4. Lowering Springs!
    By cbullock in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 06-11-2003, 02:23 PM
  5. Lowering Springs
    By Paul Ingeby in forum Saab 9000 (1984 - 1998)
    Last Post: 04-28-2002, 05:23 PM
