Strange goings on
NEWS
+ Reply to Thread
Results 1 to 6 of 6
Thread: Strange goings on
  1. #1
    Saab Junior
    Join Date
    Jan 2006
    Location
    Rotherham UK
    Posts
    32
    Strange goings on
    Hi ive got a 2001 9-3 TiD 125BHP 80,000 on the clock the problem is on a journey from sheffield to birmingham the car was only achieving 35 MPG instead of the usual 45MPG but on the way back went back upto 46MPG then after i got home i went out again drove less than 1/2 mile the enginer management light came on and seemed to go into safe mode drove straight back home turned off then on again and the light went out and seems fine
    WHATS GOING ON any help thanks chris
  2. Remove Advertisements
  3. #2
    Regular Saab Guy
    Join Date
    Apr 2005
    Location
    Surrey
    Posts
    84
    Re: Strange goings on
    Hi, if the car is running okay it might be an electrical fault. Your best bet would probably be to get the car hooked up to a tech II which would say exactly what has been registered on the computer (the chances are if the engine management light came on the computer registered a fault code).
  4. #3
    Saab Nut
    Join Date
    Mar 2005
    Location
    Gloucestershire
    Posts
    374
    Probably the Mass Airflow Meter, but these often do not throw up a CEL (check engine light) but that would be the first thing I would have looked at!
  5. #4
    Saab Junior
    Join Date
    Jan 2006
    Location
    Rotherham UK
    Posts
    32
    Can AMM be cleaned and where is it is there also some valve that can clean to hopefully get it working right
    thanks chris
  6. #5
    Saab Nut
    Join Date
    Mar 2005
    Location
    Gloucestershire
    Posts
    374
    People do clean them with varying degrees of success, because of what I do for a living, I will always buy new ones, otherwise the problem does not stay fixed. The other thing you refer to is probably the EGR (Exhaust Gas Recirculation) same issues really, you can try but you won't necessarily succeed, you need to ask the real techies who inhabit this site!
  7. #6
    Saab Newbie
    Join Date
    May 2006
    Location
    South
    Posts
    2
    I had a similar problem. Fault monitoring indicated air mass air flow meter. It turned out to be faulty wiring to this meter. A new connector solved the problem.
  8. Remove Advertisements
+ Reply to Thread
  1. Replies: 0
    Last Post: 03-06-2008, 10:32 PM
  2. Strange goings on with my 2.3 Turbo-S
    By deevee in forum Saab 9000 (1984 - 1998)
    Last Post: 10-17-2005, 12:01 PM
  3. More strange goings on!!
    By JayB in forum Saab 9000 (1984 - 1998)
    Last Post: 08-05-2005, 12:32 PM
  4. More strange goings on!!
  5. Strange
    By pwelp in forum Saab 9000 (1984 - 1998)
    Last Post: 07-09-2003, 03:31 AM
