Ignition lock cylinder
+ Reply to Thread
Results 1 to 6 of 6
Thread: Ignition lock cylinder
  1. #1
    Saab Newbie
    Join Date
    Mar 2006
    Location
    Colorado
    Posts
    3
    My key won't turn the ignition switch. '96 9000 CS, no signs of trouble prior...occasionaly would be difficult to turn the key, but rotating the steering wheel would release pressure. Now, I get a solid hit - no key rotation. I've tried moving the steering wheel, the gear shifter (automatic) and have tried rocking the car - no change. I've also sprayed WD40 and heated up the cylinder w/ hair dryer...Thanks for any suggestions.
    KP
  2. #2
    Turbo Talker Trollbooster's Avatar
    Join Date
    Feb 2005
    Location
    Whitley Bay, Northumberland
    Posts
    4,626
    Re: Ignition lock cylinder
    Have you checked the key for damage?/tried the spare one?
  3. #3
    Saab Newbie
    Join Date
    Mar 2006
    Location
    Colorado
    Posts
    3
    Yes - same issue on both keys.
  4. #4
    Sounds like something has come adrift inside the lock.
    Can the ignition barrel be taken to pieces the same as the door locks?
    I have seen door lock barrels being altered to fit existing keys when a new door lock is fitted.
    I know it doesn’t help but I just thought it might be an alternative to buying a whole new ignition barrel.
  5. #5
    Saab Newbie
    Join Date
    Mar 2006
    Location
    Colorado
    Posts
    3
    I believe you can - I have heard this anyway - but I don't know how to take it apart. I'm told I have to turn the key, before I can remove the cylinder - but I can't turn the key...I also hear, if I can take the front cover off the cyliner - then I may be able to work the tumblers enough to turn the key and remove...
    Any help getting the lock cylinder out - or removing the cylinder front cover will be greatly appreciated.
    Thanks.
  6. #6
    Join Date
    Feb 2005
    Location
    Posts
    4,626
    Yes, you have to be able to turn the key to remove the cylinder.
    There is a small hole to access a plunger that prevents the key popping out and this will only happen with the key in a certain position. To take the barrel out of the ignition lock, you will need to follow one of the procedures on a recent post here
    If you can't rotate the key to get it out then you would need to use destructive methods to remove it.
    A better bet might be to replace the lock set as a whole - they do pop up on the usual sites and SAABScene classifieds. That way you don't need to worry about having to get a lock to fit your key, although they are available and somewhere I posted the price on the 9000 forum. The ignition lock is about £70, done to fit key, but don't hold me to that. Also you will have to wait forit to arrive.
    Edit by TB: Price would appear to be £85-89 = VAT
    HTH
  7. Remove Advertisements
+ Reply to Thread
  1. Replacing Ignition cylinder
    By Honeyman in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 12-05-2012, 01:25 AM
  2. Boot lock cylinder out!
    By williamlarkin in forum Classic Saab 900 (1979 - 1993)
    Last Post: 06-04-2009, 02:20 PM
  3. 1991 9000S Ignition Key Cylinder Lock Problems
    By tulsasaab in forum Saab 9000 (1984 - 1998)
    Last Post: 12-13-2006, 11:05 PM
  4. Lock cylinder from 9000?
    By misu in forum Classic Saab 900 (1979 - 1993)
    Last Post: 11-16-2006, 05:59 PM
  5. Ignition Cylinder
    By Ken J A in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 12-22-2003, 02:35 PM
