oil pump
NEWS
+ Reply to Thread
Results 1 to 7 of 7
Thread: oil pump
  1. #1
    Saab Newbie
    Join Date
    Mar 2006
    Location
    Indiana, USA
    Posts
    1
    oil pump
    Is the oil pump a week part on the 1987 Saab 9000 Turbo? And is it hard to change?
  2. Remove Advertisements
  3. #2
    Saab Newbie
    Join Date
    Mar 2006
    Location
    new york, rochester
    Posts
    11
    Re: oil pump
    I know it will definately not be an easy fix, but i have no clue to as if it is a weak part on the 1987. If the oil pump goes though the oil light itself will come on, usually not just the check oil level light.
  4. #3
    Turbo Talker trollbooster's Avatar
    Join Date
    Feb 2005
    Location
    Whitley Bay, Northumberland
    Posts
    4,626
    Re: oil pump
    I don't know of any reliabilty issues with the pump on an '87 car (other than it is almost 20 years old). I once changed the crankshaft sprocket on a 88 CDE and it wasn't too difficult (you work in the wheel arch with the liner removed.) I can't recall the exact layout unfortunately. I'm about to change the pump in my 9-3 and that is a case of removing the cap that retains the crankshaft seal (large circlip) I can't remember if it is necessary to remove the timing cover which is a bit of a swine to do as it is sandwiched between the head and the sump. My old 9000 is in bits so I'll try and have a look tonight.
  5. #4
    Saab Fan
    Join Date
    Jul 2005
    Location
    New Jersey, USA
    Posts
    57
    Re: oil pump
    If my 94's and 95 9k oil pump is the same as that on your 87, I'd say the SAAB oil pump is an ingenious design. It is a very robust piece of equipment which almost never fails.
  6. #5
    Join Date
    Feb 2005
    Location
    Posts
    4,626
    Re: oil pump
    And that's the view you can get from the wheel arch.
  7. #6
    Saab Fan
    Join Date
    Jul 2005
    Location
    New Jersey, USA
    Posts
    57
    Re: oil pump
    But I removed the engine just for you.
  8. #7
    Join Date
    Feb 2005
    Location
    Posts
    4,626
    Re: oil pump
    [img]/saabforum/images/graemlins/laugh.gif[/img]
  9. Remove Advertisements
+ Reply to Thread
  1. Fuel pump versus feed pump?
    By andysapora in forum Saab 9000 (1984 - 1998)
    Last Post: 12-12-2006, 10:46 AM
  2. Water Pump & Oil Pump.
    By mazy in forum Saab 9000 (1984 - 1998)
    Last Post: 08-17-2004, 11:06 AM
  3. Water Pump & Oil Pump.
  4. Oil Pump
    By gelcoat in forum Saab 9000 (1984 - 1998)
    Last Post: 02-11-2003, 09:51 AM
  5. pump
    By Stewart in forum Saab 9000 (1984 - 1998)
    Last Post: 06-15-2002, 05:33 PM
