Raindrops keep falling on my head....
NEWS
+ Reply to Thread
Results 1 to 5 of 5
Thread: Raindrops keep falling on my head....
  1. #1
    Saab Newbie
    Join Date
    Feb 2006
    Location
    Surrey UK
    Posts
    2
    ...if I'm in the back and it's raining.
    Hello from a new member.
    The (rather damp) car in question is a 1997 ® 9000 CSE 5 door.
    Quite a lot of water has started dripping through the interior roof lining in the centre where it meets the rear door hatch.
    I can't see any obvious signs of corrosion or damage on the seal, but there was quite a bit of leaf and small twig debris which I've since cleared away.
    I can't see any reference to this in any of the 9000 posts so if there's anyone out there with some clues or tips, I'd be very grateful - and hopefully drier.
    Thanks in anticipation,
    Peter
    By the way, am I the first to start with a song?
  2. Remove Advertisements
  3. #2
    Turbo Talker trollbooster's Avatar
    Join Date
    Feb 2005
    Location
    Whitley Bay, Northumberland
    Posts
    4,626
    Re: Raindrops keep falling on my head....
    there is a post here
    I think mine is leaking through the windscreen seal, or do you have a sunroof? The drain tubes may be blocked.
    Removing the door trim is a doddle, the hardest part is removing the mirror switch panel.
    Remove the Left/Right toggle (pull), remove the foam pad under it with tweezers, push the little clip forward
  4. #3
    Saab Newbie
    Join Date
    Feb 2006
    Location
    Surrey UK
    Posts
    2
    Trollbooster, thanks for the reply.
    No sunroof (sorry, I should have thought to say that at the start) and I can't see anything to suggest it's coming from the windscreen. In fact the whole ceiling is dry apart from a small patch about 300mm by 100mm at the back where it meets the hatchback door. Are there any drain points in the hatchback sill?
    Thanks again
    Peter
  5. #4
    Saab Afficionado Saviour's Avatar
    Join Date
    May 2003
    Location
    Southampton, UK.
    Posts
    1,513
    Take her through a good car wash, and have a good look round inside, this should show any leaks.
  6. #5
    Saab Fan
    Join Date
    Jan 2005
    Location
    bournemouth
    Posts
    67
    Hi,
    Yeap, had similar problem although a relatively smalll trickle that would drip in and run down the rear headrest and onto the seat.
    Inspection revealed that the hatchback seal had become a little compressed in places and not sealing tightly against the hatch.
    With a little bit of trial and error I found matchsticks and other small pieces of wood pushed into the top of the groove of the seal, and then pushed back onto the metal lip were it sits gave it that extra bit of height and allowed it to seal better.
    Hope this is of some help.
  7. Remove Advertisements
+ Reply to Thread
  1. Is it all falling apart?
    By Richard_C in forum Saab News
    Last Post: 06-23-2011, 10:12 AM
  2. Prices still falling?
    By David Martin in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 01-24-2011, 02:22 PM
  3. Wastegate rod falling off!
    By fisherb in forum Saab 9000 (1984 - 1998)
    Last Post: 11-24-2009, 01:39 PM
  4. Nobs falling off
    By kprm77 in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 10-16-2003, 04:18 AM
  5. Falling Prices?
    By sgould in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 10-07-2003, 04:48 PM
