Wiper arms keep coming loose!
+ Reply to Thread
Results 1 to 6 of 6
Thread: Wiper arms keep coming loose!
  1. #1
    Saabisti
    Join Date
    Oct 2003
    Location
    Peterborough (Canada)
    Posts
    129
    Hey everyone,
    Well, with the colder temperatures setting in around here, having windscreen wipers that function well is more important than ever. Unfortunately, I've noticed that the bolts that hold my wiper arms to the motor things (I don't know what they're called!) keep coming loose. They usually come loose when the windscreen has ice and or snow on it. I try to remove as much as I can by hand before I start the car, but still...
    Is there anything you guys know that works for this problem? Perhaps bigger bolts? Some magical glue product?
    Rocky
  2. #2
    Saab Afficionado
    Join Date
    Dec 2000
    Location
    Birmingham U.K
    Posts
    1,664
    Re: Wiper arms keep coming loose!
    Rocky,
    The arms fit unto a chamfer,check that both the inside of the arm and the drive shaft are clean and oil free,It may be worth giving both a rub with a piece of emery paper,just to rough the surfaces up a little,bolt down and all should be well.If however the blades are frozen to the screen,you are flogging a dead donkey,if you succeed in stopping the arms moving,you will burn out the motor
    mike
  3. #3
    Saabisti
    Join Date
    Oct 2003
    Location
    Posts
    129
    Aha! a chamfer... that's what it's called...
    I'll try what you suggested this weekend. I just tightened them with a socket wrench, and so far no problems. That's true, I suppose... better to have the wiper arms come loose than burn out the motor!
    thanks!
  4. #4
    Motor Mouth
    Join Date
    Feb 2001
    Location
    Cheltenham. Gloucestershire, UK
    Posts
    2,886
    Aren't the driveshafts on the wiper shafts actually ridged to help lock the arms on firmly? If they've slipped a few times it might be that the soft alloy of the wiper arm base has worn and the hole is getting a bit large.
    I did find on one of my previous 9000s that the wiper nuts dont tighten up properly if you try to tighten them up with the blade lying against the windscreen.
  5. #5
    Saab Nut
    Join Date
    Oct 2003
    Location
    West Sussex, UK
    Posts
    411
    StephenA is right, the arms fit onto straight grooves, if your fitment isn't right you have to lift the whole arm off and slot it back placed differently on the grooves, there's no rotating an arm back and forth to get it right when it's on the chamfered drive shaft. And the arms have to be lifted into their up-off-the-screen position BEFORE you tighten any fixture!! If the chamfered shafts are burred there's no fixing them. They HAVE to be replaced. Beware MOT time if you don't.
  6. #6
    Saab Afficionado
    Join Date
    Apr 2002
    Location
    Coventry, UK.
    Posts
    1,908
    Yep - the wiper arms slot over a 'splined' drive shaft. If securing nut comes loose, the arms will fail to turn and could churn some of the spline ends off.
    Due to sping tension in securing end of wiper arm, if nut is loose the arm tends to push itself off of the splined drive, which largely disconnects the arm from the drive.
    Clean up splines, and retighten nut securely should do the trick - try some locknut if really necessary, and splines quite badly damaged (as they will be if joint leftloose for too long!)
    Happened on one of my earlier 9000's after 140k miles ish.
  7. Remove Advertisements
+ Reply to Thread
  1. front wiper arms
    By darky in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 02-19-2011, 09:05 AM
  2. Replacing Wiper Arms?
    By hutchingsp in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 12-04-2005, 07:24 AM
  3. wiper arms
    By mikeduffy42 in forum Saab 9000 (1984 - 1998)
    Last Post: 07-25-2005, 08:15 AM
  4. wiper arms
  5. Wiper arms keep coming loose!
    By anarkietown in forum Saab 9000 (1984 - 1998)
    Last Post: 12-16-2004, 08:36 AM
