cromwell
20 Jul 2010, 07:36
Hi- I'm new and have just bought a 2000 9-5. I've put the tyre pressures at 32 PSI but they still don't look particularly firm and 'squash down' a bit. Is this just typical of the car (I had a BMW e36 and the tyres always looked a little flat despite being at the correct inflation) or should I inflate a bit more?
Thanks.
James
sgould
20 Jul 2010, 08:18
Welcome!
The recommended tyre pressures are on the label on the door pillar. But I used to run my 1998 car at slightly higher than recommended. Halfway between the "low speed" recommended and the "high speed/loaded" figure.
NedLudd
20 Jul 2010, 15:25
Ditto really.
You don't say what wheel size, but I used to run the 16s on my old 9-5 saloon, where the range was 32 to 39, at 37/38 all round, even when driving solo and unladen. 32 certainly always felt way too spongy.
quinophex
20 Jul 2010, 16:45
I think my 16"s are set at about 36psi, they were around 38psi when I was running Pirellis with a 93 load index but now I'm on Neutons with a load rating of 97 they were far too crashy so needed to go down a bit.
phil_saab
26 Jul 2010, 05:28
My 9-5 Aero on 17s has a pressure of 36/38psi.
Machpoint005
26 Jul 2010, 10:48
QUOTE(phil_saab @ 26 Jul 2010, 06:28 )
Same for me - 9-5 TiD sportwagon on 17" wheels (225/45R17 IIRC)
sean.t
26 Jul 2010, 17:04
me also,9-5 aerowagon,36psi
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
