| blog.elkparts |
17 Mar 2006, 10:29
Post
#1
Saab Nut ![]() ![]() Group: Members Posts: 359 Joined: 13-December 02 From: Paisley Area Scotland Member No.: 16,145 |
Can anyone tell me the flash sequence codes for the Check Engine display?
I have tried searching the forum archives however maybe I am missing the obvious. I had no trouble before the board layout changed. Search was slower then but seemed to me to be able to find what I was looking for much easier. Or is it that I am just getting older? deebel |
17 Mar 2006, 10:50
Post
#2
![]() Saab Anorak ![]() ![]() ![]() Group: Members Posts: 1,194 Joined: 17-June 03 From: Wagga Wagga, NSW, Australia Member No.: 16,749 Location:Wagga Wagga, Australia |
This is the flash codes for trionic 5 ECUs
2 Flashes - MAP sensor 3 flashes - Intake air temperature sensor 4 flashes - Coolant temperature sensor 5 flashes - Throttle position sensor 6 flashes - Oxygen sensor (lambda probe) 7 flashes - Fuel / air mixture 8 flashes - EVAP valve 9 flashes - faulty ecu Courteous Saabcentral Saab 9000 FAQ |
17 Mar 2006, 20:49
Post
#3
Thanks Grentarc
I do have it printed off somewhere and filed carefully. One day I will find it. deebel |
17 Mar 2006, 23:22
Post
#4
Gas Flowed Head ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,214 Joined: 26-March 02 From: Bedfordshire Member No.: 14,955 |
If your cars (listed as 1993 in your profile) are DI/APC instead of Trionic, then use the following instead:
2 flashes - ROM check (check sum check) 3 flashes - Watchdog (control module fault). This fault can also be caused by a defective spark plug or defective ignition discharge module. 4 flashes - Knock sensor (no signal or signal incorrect) 5 flashes - Engine load signal from LH or pressure from the manifold absolute pressure (MAP) sensor incorrect. |
17 Mar 2006, 23:24
Post
#5
thanks Bill..
maybe we should have a sticky in the 9000 section withthe flash codes for everyone... probably make it easier! |
18 Mar 2006, 00:37
Post
#6
Saab Anorak ![]() ![]() ![]() Group: Members Posts: 1,738 Joined: 30-September 02 From: Dorset, UK Member No.: 16,004 |
It used to be on saabs.info, but that seems to have gone which is a real shame. What happened, Andrew? Maybe if it's not coming back, Bill could host some of the stuff on Saab9000.com.
18 Mar 2006, 01:00
Post
#7
Gas Flowed Head ![]() ![]() ![]() ![]() ![]() Group: Administrators Posts: 8,725 Joined: 1-September 00 From: Mulbarton, was Deepest Mid Norfolk Member No.: 15,768 Location:Mulbarton, was Deepest Mid Norfolk |
Sticky-ed for now.
Andrew |
18 Mar 2006, 10:47
Post
#8
Quote: Keep meaning to. It's already there on wap.saab9000.com. Might make a point of doing it today. |
18 Mar 2006, 13:23
Post
#9
19 Mar 2006, 22:11
Post
#10
So nobody noticed I'd got the procedure for reading the DI/APC codes wrong. All fixed now. Some things you just get away with ...
20 Mar 2006, 08:05
Post
#11
Bill - never owned a DI/APC, so never needed to!
12 Apr 2006, 15:47
Post
#12
Thanks Bill
3 Jan 2007, 11:16
Post
#13
Saab Junior Group: Members Posts: 15 Joined: 2-October 06 From: Christchurch , New Zealand Member No.: 22,715 |
Check Engine Codes for Bosch Motronic LH2.4 fuel injection ecu (DI /APC)
Note: If you have a flashing check engine light due to DI/APC faults as listed in other posts, these need to be cleared before you can read the Motronic stored fault codes. If you dont clear these first the flashing codes from DI/APC system overlay the flash codes called via the diagnostic connection jumper and they will not be descernable! I have also encountered 3 check engine flashes from the DI/APC system ecu where the fault has been the crank angle sensor and not an internal error of the DI/APC ecu. Saab 900 / 9000 LH 2.4 fault codes (not trionic) code cause possible cure 12111 Learning fault in lambda(air fuel mixture adj) vacuum leak,oxygen sensor,air mass meter 12112 Learning fault in lambda(air fuel mixture adj) vacuum leak,oxygen sensor,air mass meter 12113 learning fault idling adj. too low Iac valve, dirty ground points,bad ecu 12114 learning fault idling adj. too high Iac valve, dirty ground points,bad ecu 12211 battery + voltage below 10 volts or above 16 Battery, alternator,wiring 12212 throttle position switch's idle contact faulty throttle switch adj. or itself, 12213 throttle position switch's wide open throttle faulty throttle switch adj. or itself, 12214 engine coolant temp sensor signal faulty (ntc)eng temp sesor on intake mani fold 12221 mass air sensor no signal mass air flow sensor 12222 idle adj faulty Iac valve 12223 fuel air mixture too lean vacuum leak,oxygen sesor,air mass meter 12224 fuel air mixture too rich oxygen sesor, air mass meter 12225 oxygen sesor preheating faulty blown or missing fuse,bad oxygen sesor 12231 No igntion signal this always comes on as first code as engine is not on ignore unless car won't start 12232 Voltage for memory>1 volt wiring 12333 eprom fault ecu ( brain) 12241 injector faulty this code comes up a lot but is normally false(ignore) 12242 no air mass sensor filament burn off bad air mass meter 12243 no speed signal 12244 no drive signal to pin 30 12245 egr function faulty cloged egr valve(if this code comes up you should have ecu replaced and blank off egr) 12251 throttle position sensor faulty tps fault 12252 evap purge fault 12254 no rpm signal this is pin 1 on all LH ecu's 22511 load signal to ezk(ign)failed 22512 knock sensor fault 0000 no faults USEFUL LINKS: http://www.saabnet.com/tsn/faq/lhoverview.html http://www.auto-diagnostic-codes.com/Petro...-Injection.html http://townsendimports.com/Web/engine_folder/24codes.htm http://www.saab9000.com/procedures/powertr.../faultcodes.php http://www.troublecodes.net/Saab/ Hope this helps with solving your problems! Mike New Zealand |
19 Dec 2007, 07:25
Post
#14
Saab Newbie Group: Members Posts: 5 Joined: 21-November 07 Member No.: 26,747 Location:Crawley, West Sussex |
Check Engine Codes for Bosch Motronic LH2.4 fuel injection ecu (DI /APC) Note: If you have a flashing check engine light due to DI/APC faults as listed in other posts, these need to be cleared before you can read the Motronic stored fault codes. If you dont clear these first the flashing codes from DI/APC system overlay the flash codes called via the diagnostic connection jumper and they will not be descernable! I have also encountered 3 check engine flashes from the DI/APC system ecu where the fault has been the crank angle sensor and not an internal error of the DI/APC ecu. Saab 900 / 9000 LH 2.4 fault codes (not trionic) code cause possible cure 12111 Learning fault in lambda(air fuel mixture adj) vacuum leak,oxygen sensor,air mass meter 12112 Learning fault in lambda(air fuel mixture adj) vacuum leak,oxygen sensor,air mass meter 12113 learning fault idling adj. too low Iac valve, dirty ground points,bad ecu 12114 learning fault idling adj. too high Iac valve, dirty ground points,bad ecu 12211 battery + voltage below 10 volts or above 16 Battery, alternator,wiring 12212 throttle position switch's idle contact faulty throttle switch adj. or itself, 12213 throttle position switch's wide open throttle faulty throttle switch adj. or itself, 12214 engine coolant temp sensor signal faulty (ntc)eng temp sesor on intake mani fold 12221 mass air sensor no signal mass air flow sensor 12222 idle adj faulty Iac valve 12223 fuel air mixture too lean vacuum leak,oxygen sesor,air mass meter 12224 fuel air mixture too rich oxygen sesor, air mass meter 12225 oxygen sesor preheating faulty blown or missing fuse,bad oxygen sesor 12231 No igntion signal this always comes on as first code as engine is not on ignore unless car won't start 12232 Voltage for memory>1 volt wiring 12333 eprom fault ecu ( brain) 12241 injector faulty this code comes up a lot but is normally false(ignore) 12242 no air mass sensor filament burn off bad air mass meter 12243 no speed signal 12244 no drive signal to pin 30 12245 egr function faulty cloged egr valve(if this code comes up you should have ecu replaced and blank off egr) 12251 throttle position sensor faulty tps fault 12252 evap purge fault 12254 no rpm signal this is pin 1 on all LH ecu's 22511 load signal to ezk(ign)failed 22512 knock sensor fault 0000 no faults USEFUL LINKS: http://www.saabnet.com/tsn/faq/lhoverview.html http://www.auto-diagnostic-codes.com/Petro...-Injection.html http://townsendimports.com/Web/engine_folder/24codes.htm http://www.saab9000.com/procedures/powertr.../faultcodes.php http://www.troublecodes.net/Saab/ Hope this helps with solving your problems! Mike New Zealand Im having knock sensor problems. Saab read these codes out for me: 44661, 42930, 22451. I would like to know what they mean before I get anything done. The service/sales bloke didnt know.. Thanks |
19 Dec 2007, 07:54
Post
#15
44661 is error in the knock sensor circuit
42930 is? 22451 is Weak Mixture (1991 on) CODE ECU fault codes and how to read them.
Contributed by Andrew A guide to pulling fault codes for all models of electronically fuel injected Saabs to 1998. The guide also has a list of fault codes and their meaning. Guide is broken down by type of ECU/Fuel Injection. Contents Index of vehicles Self-Diagnosis Introduction Self-Diagnosis connector location Retrieving fault codes without a fault code reader (FCR) - flash codes Clearing fault codes without a fault code reader (FCR) Actuator testing without a fault code reader (FCR) - Bosch LH2.4 only Self-Diagnosis with a fault code reader (FCR) Guide to test procedures Fault code tables Index of vehicles Model Engine code Year System 900i 16V DOHC B202i 1989 to 1990 Lucas 14CU LH-Jetronic 900 Turbo 16V DOHC B202 2S 1988 to 1990 Lucas 14CU LH-Jetronic 900 2.0 16V DOHC cat B202 2L 1989 to 1993 Lucas 14CU LH1-Jetronic 900i 16V DOHC cat B202i 1990 to 1993 Lucas 14CU LH-Jetronic 900S Turbo cat B202i 1990 to 1993 Lucas 1 4CU LH-Jetronic 900 2.Oi 16V DOHC B202i 1993 to 1997 Bosch Motronic 2.10.2 900 Turbo 16V DOHC B202i 1994 to 1997 Saab Trionic 900i 16V DOHC B206i 1994 to 1997 Bosch Motronic 2.10.2 900i 1 6V DOHC B204L 1994 to 1997 Bosch Motronic 2.10.2 900 2.3i 16V DOHC B234i 1993 to 1997 Bosch Motronic 2.10.2 900 2.5i 24V DOHC B258i 1993 to 1997 Bosch Motronic 2.8.1 9000i 1 6V cat B202i 1988 to 1993 Bosch LH2.4-Jetronic 9000 and CD16 B202 1991 to 1993 Bosch LH2.4.2-Jetronic 9000 16V cat B202 1988 to 1993 Bosch LH2.4-Jetronic 9000 Turbo 16 B202 1991 to 1993 Bosch LH2.4.2-Jetronic 9000 Turbo 16 cat B202 1989 to 1993 Bosch LH2.4-Jetronic 9000 2.Oi cat B204i 1994 to 1997 Saab Trionic 9000 2.0 Turbo cat B204S 1994 to 1997 Saab Trionic 9000 2.0 Ecopower B202S 1992 to 1993 Bosch LH2.4-Jetronic 9000 2.0 Turbo Intercooler B204L 1994 to 1997 Saab Trionic 9000i 2.3 cat B234i 1990 to 1991 Bosch LH2.4.1-Jetronic 9000i 2.3 cat B234i 1991 to 1993 Bosch LH2.4.2-Jetronic 9000 2.3i cat B234i 1994 to 1997 Saab Trionic 9000 2.3 Turbo cat B234L 1994 to 1997 Saab Trionic 9000 2.3 Turbo cat B234R 1994 to 1997 Saab Trionic 9000 2.3 Turbo cat B234R 1993 Saab Trionic 9000 2.3 Turbo cat B234L 1991 to 1993 Bosch LH2.4-Jetronic/Saab Direct Ignition 9000 2.3 Ecopower LIP Turbo B234E 1994 to 1997 Saab Trionic 9000 3.0 24V DOHC B308i 1995 to 1997 Bosch Motronic 2.8t Self-Diagnosis Introduction The engine management systems fitted to Saab vehicles are Lucas 14CU, Bosch 2.8.1 and 2.10.2, Saab Trionic and Saab Direct Ignition (with Bosch LH 2.4.1 and 2.4.2 fuel injection). Bosch Motronic controls fuel Injection, ignition and idle functions from within he same control module. Saab Trionic controls the ignition, fuel injection, idle and turbo boost pressure. Saab Direct Injection controls ignition and Turbo boost alone. Lucas 14CU and Bosch LH fuel injection systems control fuel injection and idle functions alone. Self-Diagnosis (SD) function Each ECM (electronic control module) has a self-test capability that continually examines the signals from certain engine sensors and actuators, and then compares each signal to a table of programmed values. If the diagnostic software determines that a fault is present, the ECM stores one or more fault codes in the ECM memory. Codes will not be stored about components for which a code is not available, or for conditions not covered by the diagnostic software. Saab models generate either 2- or 5-digit fault codes, which may be retrieved either by fault code reader (all systems) or by manual means as flash codes (all except Saab Trionic and Saab Direct Ignition). Limited operating strategy (LOS) Saab systems featured in this Chapter utilise LOS (a function that is commonly called the “limp-home mode”). Once certain faults have been identified (not all faults will initiate LOS), the ECM will implement LOS and refer to a programmed default value rather than the sensor signal. This enables the vehicle to be safely driven to a workshop/garage for repair or testing. Once the fault has cleared, the ECM will revert to normal operation. Adaptive or learning capability Saab systems also utilise an adaptive function that will modify the basic programmed values for most effective operation during normal running, and with due regard to engine wear. Self-Diagnosis (SD) warning light Saab models are equipped with an SD (Check Engine) warning light located within the instrument panel. Some fault conditions will illuminate the light during normal engine operation, and the ECM will need to be interrogated to determine if fault codes are indeed stored in ECM fault memory. Self-Diagnosis connector location Bosch Motronic and Saab Trionic The 16-pin SD connector for FCR use and manual code retrieval is located either under the facia on the driver’s side above the foot pedals (see illustration 29.1) or under the passenger’s seat. Lucas I4CU The 3-pin SD connector is for FCR use and manual code retrieval, and is located in the engine compartment, adjacent to the heater air intake. Bosch LH2.4, 2.4.1,2.4.2 The SD connector for FCR use and manual code retrieval is situated in one of the following locations: under the rear seat, in the engine compartment, or in front of the gear selector. Saab Trionic and Saab Direct Ignition The SD connector is black, and is located close to the ECM under the right-hand front seat. Retrieving fault codes without a fault code reader (FCR) - flash codes Note: During the course of certain test procedures, it is possible for additional fault codes to be generated. Care must be taken that any codes generated during test routines do not mislead diagnosis. All codes must be cleared once testing is complete. Lucas I4CU I Attach an accessory switch between the SD connector and earth (see illustration 29.2). 2 Switch on the ignition and the SD warning light will illuminate. 3 Immediately close the accessory switch. The SD warning light will extinguish and then illuminate for one short flash. 4 Immediately open the accessory switch. 5 The SD warning light will display the 5-digit fault codes as follows: a) The five digits are indicated by five series of flashes. b) The first series of flashes indicates the first digit, the second series of flashes indicates the second digit, and so on until all five digits have been flashed. c) Each series consists of a number of flashes separated by short pauses. Each integer (whole number) in the range 1 to 9 is represented by a number of short flashes, and each zero is represented by a longer flash. d) A pause separates each series of flashes. e) The code number “12232” is indicated by a flash, a short pause, two flashes, a short pause, two flashes, a short pause, three flashes, a short pause and two flashes. A long flash is displayed at the beginning and end of each code. 6 Count the number of flashes in each series, and record each code as it is transmitted. Refer to the tables at the end of the Chapter to determine the meaning of the fault code. 7 To retrieve the next code, close the accessory switch and wait for the SD warning light to flash once. 8 Immediately open the accessory switch, and the SD warning light will display the next 5-digit fault code. 9 Repeat the procedure until all fault codes have been retrieved. 10 If a return to the first code is required, close the accessory switch and wait for the SD warning light to flash twice, then immediately open the accessory switch. The first code will be transmitted again. 11 Five long flashes indicates that all the fault codes have been retrieved, or that no codes are stored. 12 Turn off the ignition and remove the accessory switch to end fault code retrieval. Bosch LH 2.4, 2.4.1, 2.4.2 13 Attach an accessory switch between the SD connector and earth (see illustrations 29.2 to 29.4). 14 Switch on the ignition, and the SD warning light will illuminate and then extinguish. 15 Close the accessory switch. The SD warning light will illuminate for one short flash. 16 Immediately open the accessory switch. 17 The SD warning light will display the 5-digit fault codes in the same way as described for the Lucas 14CU system (see paragraphs 5 to 12). Bosch Motronic 2.8.1 and 2.10.2 18 Attach an accessory switch between pin 6 of the 16-pin SD connector and earth. 19 Switch on the ignition. 20 Close the accessory switch for between 1 and 4 seconds. 21 Open the switch, the SD warning light will now illuminate for 2.5 seconds, extinguish and then flash to indicate the 2-digit fault codes as follows: a) The two digits are indicated by two series of flashes. b) The first series of flashes indicates the multiples of ten, the second series of flashes indicates the single units. c) A 1-second flash followed by a 0.5-second inteival indicates fault codes in tens. After a 1.5-second pause, a 1-second flash followed by a 0.5-second interial indicates units. d) Code number “12” is indicated by one 1second flash, followed by a 1.5-second pause, then two 1-second flashes with a 0.5-second pause. e) A 2-second pause separates the transmission of each individual code. 22 Count the number of flashes in each series, and record each code as it is transmitted. Refer to the tables at the end of the Chapter to determine the meaning of the fault code. 23 Turn off the ignition and remove the accessory switch to end fault code retrieval. Saab Trionic and Saab Direct Ignition 24 Fault codes can only be retrieved with the aid of a dedicated fault code reader. Clearing fault codes without a fault code reader (FCR) Bosch LH 2.4,2.4.1,2.4.2 1 Retrieve codes from the ECM by the methods described in Section 3. Note: The ECM memory can be cleared only after all codes have been transmitted and the five long flashes have been displayed. 2 Close the accessory switch, and wait for the warning light to flash three times. Open the accessory switch. The memory has now been cleared of all fault codes. All other systems 3 Disconnect the battery negative terminal for five minutes. 4 Reconnect the battery negative terminal. Note: The first drawback to this method is that battery disconnection will re-initialise all ECM adaptive values. Re-learning the appropriate adaptive values requires starting the engihe from cold, and driving at various engine speeds for approximately 20 to 30 minutes. The engine should also be allowed to idle for approximately 10 minutes. The second drawback is that the radio security codes, clock setting and other stored values will be initialised, and these must be re-entered once the battery has been reconnected. Where possible, an FCR should be used for code clearing. Actuator testing without a fault code reader (FCR) - Bosch LH2.4 only Bosch LH 2,4 only (1989 Saab 900 T16 automatic) I Attach an accessory switch between the SD connector and earth (refer to illustrations 29.2 to 29.4). 2 Close the accessory switch. 3 Switch on the ignition, and the SD warning light will briefly flash once. 4 Immediately open the accessory switch. 5 The warning light will flash the appropriate code (see the actuator selection code table at the end of this Chapter) and the first component circuit will actuate. Audible operation (typically, clicking or buzzing) of the actuator solenoid or component should be heard. Warning: When testing the injectors, there is a real danger of filling the cylinders with petrol. If testing is required for more than 1 second, disconnect the fuel pump supply (or remove the fuel pump fuse) before commencing this test. 6 Discontinue the first test, and continue with the next component by closing the accessory switch once more. 7 Wait until the SD warning light briefly flashes once, and then immediately open the accessory switch. 8 The warning light will flash the appropriate code, and the next actuator circuit will function. 9 Repeat the procedure to test each of the other actuators in turn. 10 Turn off the ignition to end the test. Self-Diagnosis with a fault code reader (FCR) Note: During the course of certain test procedures, it is possible for additional fault codes to be generated. Care must be taken that any codes generated during test routines do not mislead diagnosis. All Saab models I Connect an FCR to the SD connector. Use the FCR for the following purposes, in strict compliance with the FCR manufacturer’s instructions: a) Retrieving fault codes. b) Clearing fault codes. c) Testing actuators. d) Displaying Datastream. e) Making adjustments. 2 Codes must always be cleared after componenf testing, or after repairs involving the removal or replacement of an engine management system component. Guide to test procedures I Use an FCR to interrogate the ECM for fault codes, or (where possible) gather codes manually, as described in Sections 3 or 6. Codes stored 2 If one or more fault codes are gathered, refer to the fault code tables at the end of this Chapter to determine their meaning. 3 If several codes are gathered, look for a common factor such as a defective earth return or supply. 4 Refer to the component test procedures in Chapter 4, where you will find a means of testing the majority of components and circuits found in the modern EMS. 5 Once the fault has been repaired, clear the codes and run the engine under various conditions to determine if the problem has ‘cleared. 6 Check the ECM for fault codes once more. Repeat the above procedures where codes are still being stored. 7 Refer to Chapter 3 for more information on how to effectively test the EMS. No codes stored 8 Where a running problem is experienced, but no codes are stored, the fault is outside of the parameters designed into the SD system. Refer to Chapter 3 for more information on how to effectively test the engine management system. 9 If the problem points to a specific component, refer to the test procedures in Chapter 4, where you will find a means of testing the majority of components and circuits found in the modern EMS. Lucas I4CU Flash! Description FCR code 13212 Throttle pot sensor (TPS) or TPS circuit 13213 Throttle pot sensor (TPS) or TPS circuit 13214 Coolant temperature sensor (CTS) or CTS circuit 13215 Throttle pot sensor (TPS) or TPS circuit 13221 Airflow sensor (AFS) or AFS circuit 13222 Idle air control 13223 Weak mixture 13224 Rich mixture 13225 Oxygen sensor (OS) or OS circuit 13231 Ignition signal 13233 Electronic control module (ECM) fault 13234 Vehicle speed sensor (VSS) or VSS circuit 13235 No “Drive” signal - automatic transmission or circuit Motronic 2.10.2, 2.8.1 Flash! Description FCR code 11 Secondary injection or circuit 12 No faults found in the ECM. Proceed with normal diagnostic methods 21 Airflow sensor (AFS) or AFS circuit 31 Air temperature sensor (ATS) or ATS circuit 41 Coolant temperature sensor (CTS) or CTS circuit 51 Throttle pot sensor (TPS) or TPS circuit 61 Oxygen sensor (OS) cylinder 1, 3, 5 or OS circuit 62 Oxygen sensor (OS) cylinder 2, 4, 6 or OS circuit 71 Oxygen sensor (OS) cylinder 1, 3, 5, rich or lean 72 Oxygen sensor (OS) cylinder 2, 4, 6, rich or lean 73 Oxygen sensor (OS) rich or lean 81 Evaporative emission canister purge valve or circuit 91 Electronic control module (ECM) 92 Electronic control module (ECM) Saab Trionic FCR Description code P0105 Manifold absolute pressure (MAP) sensor or MAP sensor circuit P0106 Manifold absolute pressure (MAP) sensor or MAP sensor circuit, signaI low P0107 Manifold absolute pressure (MAP) sensor or MAP sensor circuit, signal high P0108 Manifold absolute pressure (MAP) sensor or MAP sensor circuit P0110 Air temperature sensor (ATS) or ATS circuit P0112 Air temperature sensor (ATS) or ATS circuit, signal low P0113 Air temperature sensor (ATS) or ATS circuit, signal high P0115 Coolant temperature sensor (CTS) or CTS circuit P0117 Coolant temperature sensor (CTS) or CTS circuit, signal low P0118 Coolant temperature sensor (CTS) or CIS circuit, signal high P0120 Throttle pot sensor (TPS) or TPS circuit P0121 Throttle pot sensor (TPS) or TPS circuit P0122 Throttle pot sensor (TPS) or TPS circuit, signal low P0123 Throttle pot sensor (TPS) or TPS circuit, signal high P0130 Oxygen sensor (OS) or OS circuit P0135 Oxygen sensor (OS) or OS circuit P1130 Oxygen sensor (OS) or OS circuit, current high P1135 Oxygen sensor (OS) or OS circuit, current low P0170 Fuel/air mixture or circuit P0171 Weak mixture P0172 Rich mixture P1322 Engine speed (RPM) sensor or circuit P0325 Knock sensor (KS) or KS circuit P0335 Engine speed (RPM) sensor or circuit P0335 Crank angle sensor (CAS) or CAS circuit P0443 Carbon filter solenoid valve (CFSV) or CFSV circuit P1443 Carbon filter solenoid valve (CFSV) or CFSV circuit P1444 Carbon filter solenoid valve (CFSV) or CFSV circuit, current high P1445 Carbon filter solenoid valve (CFSV) or CFSV circuit, current low P0500 Vehicle speed sensor (VSS) or VSS circuit P0501 Vehicle speed sensor (VSS) or VSS circuit P0502 Vehicle speed sensor (VSS) or VSS circuit, signal low P0505 Idle speed control valve (ISCV) or ISCV circuit P1500 Battery voltage P0605 Electronic control module (ECM) P1651 Electronic control module (ECM) P1652 Electronic control module (ECM) Bosch LH 2.4/2.4.1/2.4.2 (flash codes) Flash Description code 12111 Oxygen sensor (OS) fault (fuel air mixture on idling) 12112 Oxygen sensor (OS) fault (fuel air mixture engine at cruising speed) 12113 Idle speed control valve (ISCV) adaption fault, pulse ratio too low 12114 Idle speed control valve (ISCV) adaption fault, pulse ratio to high 12211 Battery voltage, less than 10 volts or greater than 16 volts 12212 Throttle switch (IS), idle contacts 12213 Throttle switch (IS), full-load contacts 12214 Temperature sensor signal faulty (below 90°C or above 160°C) 12221 No air mass meter signal 12222 Air conditioning system faulty 12223 Fuel air mixture lean, OS sensor shorting to earth 12224 Fuel air mixture rich, OS sensor shorting to battery voltage 12225 Oxygen sensor (OS) or OS heater fault 12232 Voltage supply to ECM pin 4 is less than 1 volt 12233 Fault in electronic control module (ECM) - read only memory (ROM) 12241 Mixture lean 12242 Hot-wire burn-off function faulty 12243 No signal from vehicle speed sensor 12244 No “Drive” signal (automatic transmission) 12245 Exhaust gas recirculation (EGR) function faulty 00000 No faults detected, or all fault codes have been transmitted Bosch LH 2.4 ac&ator selection code table Note: The actuators will actuate in the following sequence. Listen for an audible sound, or touch the component to determine whether it has been activated Code Description No display Fuel pump circuit 12411 Injector circuit 12412 Idle speed control valve (ISCV) circuit 12413 Carbon filter solenoid valve (CFSV) circuit 12421 Automatic transmission (auto) drive signal. The SD light ceases flashing when the gear lever is moved from “D” to “N” 12424 Throttle switch (IS), idle contacts. Slightly open the throttle. The SD light ceases flashing once the throttle moves away from the idle position 12431 Throttle switch (IS), full-load contacts. Fully open the throttle. The SD light ceases flashing as the throttle approaches the fully-open position Bosch LH 2.4/2.4,2 and Saab Direct Ignition (FCR codes) FCR code FCR code (permanent) (intermittent) Description 11111 - Reply code for OK 42241 22241 High voltage (1991 -on) 42251 22251 Electronic control module (ECM) pin 4, signal low 42252 22252 Signal low, less than 10 volts 42291 22291 Battery voltage, less than 10 volts/greater than 16 volts 42440 22440 Oxygen sensor (OS) or OS circuit, rich mixture 42441 22441 Rich mixture, idling (1991-on) 42442 22442 Rich mixture, driving (1991-on) 42450 22450 Oxygen sensor (OS) or OS circuit, weak mixture 42451 22451 Weak mixture, idling (1991-on) 42452 22452 Weak mixture, driving (1991-on) 42460 22460 Oxygen sensor (OS) or OS circuit 42491 22491 Idling mixture incorrect 42492 22492 Driving mixture incorrect 44221 24221 Engine RPM signal absent (1991-on) 44261 24261 Vehicle speed sensor (VSS) or VSS circuit (1991-on) 44360 24360 Crank angle sensor (CAS) or CAS circuit 44460 24460 Engine load signal faulty 44660 24660 Pre-ignition fault (knocking or pinking) 44661 24461 Knock sensor (KS) or KS circuit 44662 24462 Combustion, synchronising fault 44671 24671 Pre-ignition signal over 20 seconds 45641 25641 Mass airflow (MAF) sensor or MAF sensor circuit, signal high 45651 25651 Mass airflow (MAF) sensor or MAF sensor circuit, signal low 45691 25691 Mass Airflow (MAF) sensor or MAF sensor circuit 45723 25723 “Drive” signal (automatic transmission) 45771 25771 Throttle pot sensor (IPS) signal or IPS circuit 45772 25772 Throttle pot sensor (IPS) signal or TPS circuit 46221 26221 Coolant temperature sensor (CTS) or CTS circuit, signal low 46271 26271 Coolant temperature sensor (CTS) or CTS circuit, signal high 46391 26391 Exhaust gas recirculation (EGR) system or EGR circuit 58121 38121 Mass airflow (MAF) sensor or MAF sensor circuit, bum-off absent 58321 38321 Air conditioning valve function or circuit 58322 38322 Evaporative loss control device (ELCD) valve function or circuit 58371 38371 Injector or injector circuit 58372 38372 Evaporative loss control device (ELCD) valve or circuit 58382 38382 Evaporative loss control device (ELCD) valve short-circuit (1991-on) 60000 - Internal monitoring 60001 - Read only memory (ROM) fault 60002 - Random access memory (RAM) fault 67192 - Electronic control module (ECM), read only memory (ROM) Trionic flash codes flashes component correspondingisat codes 2 Manifold absolute pressure sensor p0105, p0106, p0107, p0108 3 Intake air temp sensor p0110, p0112, p0113 4 coolant temp sensor p0115, p0117, p0118 5 throttle position sensor p0120, p0121, p0122, p0123 6 oxygen sensor p0130 7 Air fuel mixture p0170, p0171, p0172 8 Evap valve (ELCD) p0443, p1443, p1444, p1445 |
22 Feb 2008, 02:33
Post
#16
Saab Newbie Group: Members Posts: 11 Joined: 26-October 07 From: Puerto Rico Member No.: 26,426 Location:Isabela, Puerto Rico |
I have a '89 9000 Turbo 16V cat B202 Bosch LH 2.4 Jetronic/DI/APC but don't see a listing for that until 1991 and only on the 2.3. What's up?
Also I'm getting 5 flashes with the key on, not running. Once running no Check Engine light. Is that normal? Thanks |
22 May 2008, 09:19
Post
#17
![]() Saab Anorak ![]() ![]() ![]() Group: Members Posts: 1,500 Joined: 22-May 03 From: Southampton, UK. Member No.: 16,665 Location: 50°56'4.55 |
There's some more info HERE
13 Aug 2009, 12:15
Post
#18
Saab Newbie Group: Members Posts: 7 Joined: 31-January 08 Member No.: 27,644 Location:Australia |
Where is the Intake Air Temperature Sensor - fault code indicates 3
13 Aug 2009, 12:38
Post
#19
Gas Flowed Head ![]() ![]() ![]() ![]() ![]() Group: Administrators Posts: 13,492 Joined: 10-July 02 From: Leighton Buzzard Member No.: 15,921 |
16 Feb 2010, 07:33
Post
#20
Saab Newbie Group: Members Posts: 8 Joined: 15-January 10 Member No.: 41,798 Location:hanford Ca USA |
does any one have fault code retrieval for an 86 9000 turbo. i have a feeling that the ecu is bad but dont have a code reader for it.
Lo-Fi Version | Time is now: 31st July 2010 - 22:50 |
